George16
Supermaxx
George16's Avatar
11.19.2008, 05:19 AM
Originally Posted by pasan View Post
I'm not too familiar with how mechanical brakes work in parallel with an ESC. Do you use a Y connector?
You can use a Y connector for the ESC and brake or you can just use the 3rd channel of your tx/rx and mix throttle and brake. This is how I set up my revo conversion because I don't like using a Y connector.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
123revo
11.19.2008, 08:00 AM
yes thats how it is currently setup with the stock traxxas servo but for some reason it doesnt like the 645mg servo which i find strange as from what i understand the stock traxxas is made by hi-tec...??? isnt it? regardless i find it strange and hope my next purchase of a dx3r wont complicate things further.
George16
Supermaxx
George16's Avatar
11.19.2008, 08:22 AM
Futaba and Traxxas servos have a lot of distinct similarities. Anyway, I'm using a Hitec 5955TG servo for steering.
Revo with OS .18TZ
123revo
12.07.2008, 09:28 AM
ok now i just noticed this before another packed dirt bashing session. i went to connect my 5s2p 123 cells and it did the usual light show spark then arming chimes went off. i quickly realized the switch was partially in the on position and disconnected the battery. i moved the switch in to the off position then reconnected the battery. then i switched it on and the tones sounded. but no fan initialization...? i took it for a quick test up and down the driveway and worked all fine. i was a bit apprehensive in the bash session and temped the MMM every few minutes and to check the fan was tripping at the right temps. the fan did trip but now the fan doesnt initialize each time it starts. i am hoping it wont quit altogether under load and fry itself. although i understand it does have a thermal cut...right?
cause for concern? maybe a quick castle link reprogram would fix it?
pasan
I <3 RC
pasan's Avatar
12.07.2008, 10:15 AM
Try a new firmware update. If that doesn't work, better give a quick call to Castle to see whats up. I hope it's not a sign of impending doom. I had an issue some weeks ago whereby I couldn't switch the thingy *off* rather than on. It creeped me out quite a bit, let me tell you. I swear, I'm almost on egg shells with my MMM. It shouldn't be this way :(
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
123revo
12.08.2008, 07:00 AM
i dunno whats going on now. charged up my packs and voila, fan initalizes again on start up. i am not gonna argue. :P
pasan
I <3 RC
pasan's Avatar
12.08.2008, 08:07 AM
good stuff :P keeping fingers crossed, knocking on wood, etc.
AX10 RTR - Stock :D
