Go Back   RC-Monster Forums > Support Forums > Novak
lutach
lutach's Avatar
09.21.2008, 10:15 PM
Originally Posted by rchippie View Post
the one i linked comes with the larger bearing on the FR endbell .
I see. So that one sounds even better.
rchippie
rchippie's Avatar
09.21.2008, 10:20 PM
Yes it does . Besides the upgraded rotor wont fit with out the larger bearing .
REAL MEN RUN BRUSHLESS
rchippie
rchippie's Avatar
09.22.2008, 02:43 PM
Lutach
I talked to a novak tech today . I told him what i told you & he suggested the same thing. But i noticed there is a faint smell coming from the motor. when i told him this he said it sounds like it maybe more than the rotor thats messed up . so im not going to buy a rotor kit , only to find out something elese is wrong . so i guess im going to have to buy a new motor .
09.22.2008, 02:57 PM
Is the smell simply "that new motor" smell? Even when not new, the varnish does have a distinctive odor.
Coil windings are so short that they have very little DC resistance, so getting a reading with an ohmmeter is all but impossible. However, you could build a simple oscillator (555 timer based) running at ~20kHz. Add a little "current amplifier" to the output (1A max), and hook each motor lead to it with a precision 1ohm resistor in series. The voltage drop on the resistor should be equal on all phases.
rchippie
rchippie's Avatar
09.22.2008, 03:17 PM
In all honesty it kind of has that burnt motor smell . But it's not a very stronge smell .
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
09.22.2008, 05:14 PM
I demagged my HV4.5 5mm shafted rotor. I put the orginal rotor back in and it worked fine. The motor had a burned smell too. You can always send your motor to Novak with the demagged rotor installed and they will replace it with less than the cost of a new motor.
Area 52 Ranch Raceway
T.R.C.R.
