Go Back   RC-Monster Forums > Support Forums > Novak
I think i burned my motor up .
rchippie
rchippie's Avatar
I think i burned my motor up . - 09.21.2008, 07:30 PM
As the title says . I was running a novak xbr esc with a ex 13.5 & trak power lipo's . My car is a tc4. I was running a 31/66 or 5.3 gear ratio for the first race . The temps were 175 at thermal . the second race i ran a 33/66 or 5.0 gear ratio the temps stayed the same & has a stutter at slow speed . So i tried a 29/66 or 5.8 ratio during practice the motor got hot quick & had a stutter at slow speed . The car had a stutter untill it got up to speed then it went away . But it came back when i slowed down to turn . I just took the motor apart the rotor still seems to be magnitized as it picks up the screws that hold the motor together with no problems . I switched to my speed passion 17.5r after & had no problems . So i know it's not the esc .
REAL MEN RUN BRUSHLESS
lutach
lutach's Avatar
09.21.2008, 08:32 PM
You demagnetized the rotor. Even though it still has some magnetism, it'll make your motor hot as it needs more current now to turn the rotor. I have a lot of demagnetized rotors that I sometime use to magnetize some tools I use. You I used the 31/69 combo to hit 65mph in my TC3 which has the same diff ratio? With the 17.5r you have no problem and you should be able to use the bigger pinions as the 17.5r will needs it to be fast.Keep in mind if your ESC shut down because the motor got too hot, then the rotor probably went above the 175-180F mark. Most temps taken from outside the can will not tell you how the temps were inside. Open your 13.5 and check the magnet wires to see if they look ok and if they do just buy a new rotor and don't use such a big pinion or small spur.
rchippie
rchippie's Avatar
09.21.2008, 08:38 PM
what wires do you mean ?. What gear ratio & spur would you suggest for the 13.5 ?.
lutach
lutach's Avatar
09.21.2008, 08:50 PM
The copper windings. See if there's any signs of burns. You were geared for 37mph and if it was me I would've started at 30/72 and taken from there, but I don't know how big your track is so all I'm doing is given you a starting point to check temps after you race a full 5 minutes. Your motor might've had something else go wrong that caused it to heat up like you said.
rchippie
rchippie's Avatar
09.21.2008, 09:00 PM
the wires look a nice & even shinny red in color . This track had a straight approximently 140 - 150 feet long . This motor had the none sinterd rotor . I think i will just but the upgraded rotor for this motor .
lutach
lutach's Avatar
09.21.2008, 09:13 PM
Yes, just get the rotors and see how it goes. I was also under the impression the wires were supposed to have a yellowish color as most high temperature magnet wires have it. I've had wires turn that shinny red color after they had heat issues and went bad.
rchippie
rchippie's Avatar
09.21.2008, 09:27 PM
Im not sure what color they are supposed to be . I dont want to buy a rotor if the can it's self is bad . I do know that when i picked up the car & the motor had no load on it there was no stutter in the motor . I dont know if that means anything .
lutach
lutach's Avatar
09.21.2008, 09:29 PM
I'll go open a couple of motors right now to see what color the copper wires are supposed to be. Give me a few minutes.
rchippie
rchippie's Avatar
09.21.2008, 09:35 PM
thank's are they novak motors ?.
lutach
lutach's Avatar
09.21.2008, 09:38 PM
Go ahead and buy the rotor. All the Novaks I have checked uses the red colored copper wires. You just demagnetized your rotor as you stated it didn't cog like they usually do.
rchippie
rchippie's Avatar
09.21.2008, 09:44 PM
Thank you for checking . You may have saved me almost $40.00 .
lutach
lutach's Avatar
09.21.2008, 09:47 PM
No problem. I like to see the inside on my motors .
rchippie
rchippie's Avatar
09.21.2008, 09:50 PM
So motors turn you on ? . this is what im going to get .
http://www3.towerhobbies.com/cgi-bin...?&I=LXPYT1&P=7
lutach
lutach's Avatar
09.21.2008, 10:00 PM
Yes they do . Just get this one: http://www3.towerhobbies.com/cgi-bin...?&I=LXNLZ1&P=7 or this one http://www3.towerhobbies.com/cgi-bin...?&I=LXTCK3&P=7.
rchippie
rchippie's Avatar
09.21.2008, 10:09 PM
the one i linked comes with the larger bearing on the FR endbell .
