azjc
10.21.2008, 03:00 AM
THAT is awesome! How long is that motor?
Even the 60mm Medusa geared for 60mph on 6S is a WILD ride. I can only imagine what your setup is gonna do.
Just remember, big amp draw and keep an eye on your temps. That's one seriously hungry setup.
You might wanna wear a face shield to protect yourself from the rubber flying off the rims! LOL
83 mm in length
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
10.21.2008, 05:12 AM
I can not take credit for this pic, only for being smart enough to save it to my computer
I can take credit for the pic! Thats my truck!
The lotus body behind it is for my TC4.
Lookin forward to watchin this linc!
Have you considered using a bigger spur to get the clearence over the shock mount you need?
...Of course, that would mean bigger pinion, etc....
*EDIT*
Maybe run a couple of these with lutechs 10s;
http://www.hobbycity.com/hobbycity/s...Ah_21-35C_4S1P
Similar speed, and you may not need to mess with the shock mount if you get enought clearance with the larger spur.
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.8333333333333332
Other Ratio: 1
Spur Tooth Count: 54
Pinion Tooth Count: 24
Total Voltage: 29.6
Motor KV: 1577
Tire Diameter (inches): 5.9
Tire Ballooning (inches): 0
Motor Current Draw: 80
Motor coil Ω: 0.008
Spur/Pinion Ratio: 2.25 : 1
Total Ratio: 11.74038 : 1
Tire Circumference (inches): 18.54 inches (470.8 mm)
Total Motor Speed: 45669.92 RPM
Vehicle Speed: 68.28 mph (109.68 km/h)
Estimated Adjusted Speed: 62 mph (99 km/h) - 9% loss
Effective KV Value: 1542.9
KT constant: 0.86 oz-in/A
Motor Torque: 0.36 ft-lbs
Final Torque: 4.2 ft-lbs
Final Power: 2368 watts (3.2 HP)
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
bruce750i
bruce750i's Avatar
10.21.2008, 10:42 AM
We'll need some video of this bad boy. Don't leave us hanging.
10.21.2008, 10:47 AM
Don't worry. I wouldn't do that to you guys!!! It may take a few weeks, as I have a few more projects that I am working on...
lutach
lutach's Avatar
10.21.2008, 10:49 AM
I'll be watching this.
10.21.2008, 10:52 AM
I am sure that you will...
Andrew32
10.21.2008, 12:45 PM
i can just see everyone ditching the 1515 and going for the 1521...LOOK WHAT YOUVE DONE!
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
10.21.2008, 05:20 PM
If anyone needs help finding a home for their 1515, I'll give you a hand.
lutach
lutach's Avatar
10.21.2008, 05:38 PM
PM Arct1K.
BlackedOutREVO
10.21.2008, 06:14 PM
DANG!
Thats going to have some power! This will really shut the V twin people! Hahahahahaha
10.21.2008, 08:16 PM
Pfft, V-twin was a fad, which is thankfully dying out now (kinda wish I hadnt helped the noobs with it to begin with).
Will sure be fun watching that road missile when it gets that power to the ground...
MetalMan
MetalMan's Avatar
10.21.2008, 09:38 PM
If the driveshafts will allow such a thing to happen...
10.22.2008, 01:37 PM
I was more concerned about the stock Erevo diffs, they'll explode before they can even complete one rotation...
MetalMan
MetalMan's Avatar
10.22.2008, 01:39 PM
Somebody didn't read the first post . Noob .
He's using hybrid diffs .
10.22.2008, 01:42 PM
I think they will be fine. I will not bash it as hard as I usually do. Or I may upgrade to the summit driveshafts...
It will have hybrid diffs in it, your reading comprehension sucks Neil
