11.25.2008, 08:24 PM
The motors are 42mm, and they do have the same rotor size, the fins are smaller.
11.25.2008, 08:53 PM
Oh ok.
Soldermaster Extraordinaire
11.25.2008, 08:58 PM
Ahah!
11.25.2008, 09:00 PM
Alakazam!
11.25.2008, 09:06 PM
Supercalafragilisticexpialidocious!!!
RC-Monster RC8T
11.25.2008, 09:10 PM
What are you using the truggy for? Bashing, speed runs or racing? If it's racing The 60mm Medusa would even do. Mike was running a 60mm Medusa in his E-REVO last I heard and thats not a light truck either. For bashing or a mix of everything the 70mm would prolly be a better bet, but for all out speed runs while maintaining good temps go with the 80mm. As Arct1k said the CC/neus will be close to the same price but currently the best bang for your buck goes to Medusa. I've had no stripped threads on my Medusa, choose the proper length screw, apply a drop of loktite, and tighten down. No need to put a 4' pipe on the end of the allen wrench
11.25.2008, 09:18 PM
Supermegawhoopledoohdahantidisestablishmentarianis m.
11.26.2008, 09:06 AM
Ill think I go for 80mm just in case. Just to make sure there is "enought" power.
Use would be bashing on yard and some bashing on race track.
11.26.2008, 11:16 AM
When are these 70 & 80mm Medusa's going to be finally released???
They told me end of November..............ahhhhhh, heeellooooooo, we're there, so, where are my motor's!!??
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
11.26.2008, 01:15 PM
Off-topic: How much does your hyper st weigh without batteries?
11.26.2008, 02:38 PM
3,9kg with tires, with batteries 5kg.
And thats without motor. Tires weight 870g.
11.26.2008, 02:55 PM
 Mine is 3.99kg without batteries, but with motor.
11.26.2008, 05:25 PM
Originally Posted by bruce750i
No problems with my Medusa stripping threads out. You just gotta know when to say when, and put the allen down.
i tightened mine down, then i needed to change the pinion, unloosened it, when to tighten it back up, never even got snug, the taps they used are junk, i know of 6 medusas being used at the moment locally, including the one i had, and 5 stripped the threads out, that or they move because of undertightening, maybe we just all got unluckey!
11.27.2008, 09:12 AM
You dont have mechanical brakes, thats why...
And those other tires are 50g lighter, for set.
My car should be balanced fairly, as those servos and MMM weights ~350g, and that Medusa is 400g + cooling fin and front adapter.
11.27.2008, 09:17 AM
That's pretty good, my CRT weighs bang on 5kg with everything, including mechanical brakes.
I borrowed the MM from my mate to use this w/e.
My 6 still haven't turned up. :-(
Ooops, sorry, didn't mean to hijack.
