emaxxnitro
emaxxnitro's Avatar
01.30.2009, 06:09 PM
Originally Posted by sleebus.jones View Post
Holy out of focus picture batman. I think I can see something there but I'm not sure.
sorry cell phone
808E
01.30.2009, 03:03 AM
From far away, my g/f thought it was a bowl of ice cream with stuff on top! So yeah, maybe a better pic with the macro setting?
Topas
01.30.2009, 02:06 PM
Maybe I expect too much ... here is a video of the "cogging" Castle 2200
http://de.youtube.com/watch?v=QR02Vf7Mw8Y (watch it in HD !)
My hobby coin collecting: (in german)
Euromünzen
johnrobholmes
johnrobholmes's Avatar
01.30.2009, 03:34 PM
You are just at very low throttle before the motor breaks the magnet/ pole attraction- so it looks to me. Once it is above that minimum rpm do you have any studdering issues?
---JRH---
Topas
01.30.2009, 03:44 PM
Yes ... the studdering is only at a very very low throttle .... When the motor starts I have no issues ;)
Euromünzen
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.30.2009, 03:47 PM
That is not cogging! Have you tried it in your car? Motor/esc needs a minimum RPM to establish rotor position and function properly. cars/trucks/buggies all use gear reduction so that's not to much of an issue. I have aprox a 13:1 reduction on my REVO so every 13 turns of that motor only turns the wheel once. without a load on the motor you are going from nothing to about 20,000RPMs!
change your pinion to 13t and the cogging will be reduced
alangsam
change your pinion to 13t and the cogging will be reduced - 02.04.2009, 01:03 PM
i believe if you change the pinion to 13t the cogging will be much less due to gear reduction and the thing will still fly.
01.30.2009, 03:54 PM
Ok, that video helps.
Increasing the start power setting in the MMM will help with that. Being sensorless, the ESC needs to see a certain amount of rpm to know where the rotor is. Increasing the start power will "tickle" the motor a little more to spin it up so it will get an rpm reading faster.
This thread will explain the MMM settings in more detail if you want.
You are gonna have a tiny bit of cogging at very low speeds no matter what you do. Usually, this isn't a big deal since most people don't run these systems at ~1mph, not to mention ESCs/motors are not nearly as efficient at partial throttle anyhow.
Topas
01.30.2009, 03:56 PM
Ok, but the NEU 1515/1/Y runs a little smoother ;)
Euromünzen
Hardstyle
Hardstyle's Avatar
01.30.2009, 05:40 PM
I have wondered myself too that little clitch, running at very slow speed. Really aren't a problem unless if you wan't to crawl with it
