rootar
rootar's Avatar
02.07.2009, 01:44 AM
what kv 1515 is that?
plettenbergs
plettenbergs's Avatar
02.07.2009, 09:04 AM
not sure the kv?...the box for the motor says...1515/1y/f
i have my 5s Zippy's ready to go!
George16
Supermaxx
George16's Avatar
02.07.2009, 09:19 AM
TeknoRC Neu 1515 1Y = 2200Kv
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
rootar
rootar's Avatar
02.07.2009, 10:37 PM
i dunno if you ran it yet or not but you might want to drop atleast couple teeth on your pinion when you bump up to 5s especially since you went to a small spur....or youll be geard to the moon.
plettenbergs
02.07.2009, 10:50 PM
i tried to run today!...i am using my new Hyperion charger for the first time and did not charge the batts properly...i balanced but did not charge after...my bantam charger abances and charges at the same time...the 0610i balances then you have to charge after!!
also cant run 5s until i remove the TRAXASSS bat comectors from the MMM esc!...i will just run the 4s with the 17/46 and keep a close eye on temps!
i will let you guys know how it goes!!
George16
Supermaxx
George16's Avatar
02.07.2009, 11:04 PM
The 0610i balances and charges at the same time .
Revo with OS .18TZ
plettenbergs
02.08.2009, 12:23 AM
i did something wrong...got out to run and lvc kicked in instantly!
the 4s bat only had 12.4 volts...it must not have charged!
user error i think...got it to charge just now up to 5000mah and 16.8 volts...also charged up the dual Plett Emaxx!
SHOULD BE A GREAT DAY IN ATLANTA FOR R/C!!!(mid 70'S)
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
02.19.2009, 04:17 AM
any updates?....i just converted my rc8t initially running 16/50 but wasn't happy with the speed so i changed it to 18/50 and am much happier but i haven't had any track time to thorughly test this gearing...how is the 46t working out for you and what pinion are you using?
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
plettenbergs
02.19.2009, 05:56 PM
i ran it the other day with great success(not at a track)...i am not a racer just back yard basher...with the 17/46 gearing it hauled MAJOR ass...even pulled wheelies on command...i love this truck...very light and handles like a dream...motor temps were in the 160 range,batt was cool and MMM was around 100...this MMM v1(purchased new 10/08) has the new case and a NOVAK fan...is it normal for the fan to stay on all the time?
i need to remove the TRAXXASS batt plugs from the MMM so can run my 5s ZIPPYr's in this bad boy....i will get some video of that when the weather clears up!!...should be AMAZING on 18.5v
bruce750i
bruce750i's Avatar
02.19.2009, 06:28 PM
V1 MMM's fan runs 100% of the time.
plettenbergs
02.20.2009, 11:03 PM
thanks for the info...the mmm sure runs cool for now
i have new Deans on everyhting and will run the truck tomorrow on 5s...18.5 volts on the 1515 1y should rock!!...i have three batts charged and ready to go...I hope the drive train will hold up to my 5 and 9 year old boys!
will have video tomorrow of the the boys...i will be filming this time...i will also have Dual Plett Supermaxx...R/C day!!!...it better not freekin rain!!
