Metallover
RC-Monster Spudgunner
Metallover's Avatar
04.06.2009, 08:19 AM
Originally Posted by johnrobholmes View Post
Another 5:1 would be your best bet. Can you pedal at 35mph though? search google for top hat adapter, you could put a 36t sprocket on your disc brake side and get all the geardown you need with your stoker setup.
Just going down in KV won't help, you will loose all of your power.
YEAH!! That's awesome. Not only will it work and be easy, but it will suit all me needs and it will be more efficient. I'm going to do some more research. Feel free to show me what I would need.
I just did some math and I'll need a 14/185 pinion/spur to do it all in one shot.
johnrobholmes
johnrobholmes's Avatar
04.06.2009, 10:17 AM
You won't be able to do a single stage reduction with that motor.
A 14/72 into 14/36 would be about as close as you can get to ideal, although a larger than 36t rear sprocket would be better. The only hitch with using the top hat adapter is that you will need a left side drive freewheel.
---JRH---
Metallover
Metallover's Avatar
04.06.2009, 09:41 PM
A straight reduction is about 10/180 iirc. If I used some small chain it might be possible... I want to keep my current setup but just get a couple different gears so I have a low and high gear with the motor.(8 total) I have a 2 hour study hall tomorrow, I should be able to figure it out.
