Chris911
01.21.2006, 03:03 PM
Originally posted by squeeforever
then i would go with the xl. not to mention i think the january deal is over.
yeah i don't see it on the front page anymore.
boss 302
01.21.2006, 03:41 PM
the deal ended on the 15th
captain harlock
RC-Monster Captain
captain harlock's Avatar
01.21.2006, 09:08 PM
Well, a XL is going to be much better indeed. Go for flm hybrids and a single speed conversion from G-MAXX. The s.speed conv. would help you get some more speed, too.
Nice to meet you!
Chris911
01.22.2006, 01:28 AM
What XL are you guys talking about there is more than one and why is a XL going to be better than a Feigao 540 10L? I'm only guessing that the 10L is the best Feigao? I don't know what numbers to look at to see what motor has the most speed or power?
Can you explain how you know?
The Warrior 9920 will work with almost any motor?
btw do you guys think that the Maximizers would hold up?
boss 302
01.22.2006, 01:37 AM
if you want long runtime use a 9xl
for more speed use a 7xl
and for somewhere inbetween use an 8xl
the warrior 9920 will work with any of those motors the 9920 can handle up to 20 cells and 99 amps continuous also when using more than 12 cells you will need a ubec or reciever pack and instead of using a fiego motor get a BK because they have better bearings
captain harlock
RC-Monster Captain
01.22.2006, 06:33 AM
There are three sizes of these brushless motors:
S= short can and rotor= standard size motor. No good for big trucks.
L= long can and rotor= 10mm longer than the S size= more torque and run time= good for stock e-maxx
XL= Xtra long can and rotor= 10mm longer than the L size= tons of torque and a very good amount of run time, too.
The 9920 should work with most of them, but not all of them.
As Boss302 said, the Wanderers have better bearings than the Feigaos.
Nice to meet you!
Chris911
01.22.2006, 09:54 AM
What is a ubec or reciever pack?
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.22.2006, 11:25 AM
UBEC is an external "battery elimination circuit". It takes power from your main batteries and regulkates it to a constant 6 volts to power your servos. The controllers have a built in BEC, but it is less efficient, provides less voltage to the servo, and is only rated for 12 cells.
boss 302
01.22.2006, 03:07 PM
also it would protect the controller if the ubec goes out it would be a $35 dollar fix rather than buying a whole new controller if the internal bec went out
Chris911
01.22.2006, 05:07 PM
squeeforever
squeeforever's Avatar
01.22.2006, 05:20 PM
there 7075 aluminum. they should hold up easily.
Chris911
01.22.2006, 11:15 PM
so if i get a differant esc like the warrior and use any amout of cells i have to use a UBEC?
boss 302
01.22.2006, 11:17 PM
you would have to use a ubec on anything over 12 cells
Chris911
01.23.2006, 12:06 AM
I'm using 14 cells now but i assume you mean with the warrior?
Is the Maximizer worth getting or should i just get UE's diffs? If i get the Maximizer whats a good diff case to put them in? Whats the option of them for robinson gear mean?
I would also like to replace the stock Steering Block i guess this will do? but where do i find the rear ones?
Thanks!
boss 302
01.23.2006, 08:00 AM
correct
