ikpthegame
11.02.2009, 05:24 AM
i dont know what your truck is using for a spur but i run the kyosho 44 or 46 tooth nylon spurs http://www.rc-monster.com/gears.php?pg=3 and if for some reason something happens the spur would give before the pinion would. so in the long run it would be a better choice based on price. my truck came with a 53 tooth spur and i run the 46 tooth and gear it to the speed i want to get.
kneedeeppow
is lovin life brushless
kneedeeppow's Avatar
11.03.2009, 12:27 AM
do the kyosho spurs fit mugen diffs? is there any performance differences from the steel to nylon spurs?
associated rc8t..........e
tamiya f104pro,r,w.f103gt.tb02,ta02
nuova faor sf501
avatar is pic of what our cat does with empty boxes left over from rc purchases
bruce750i
bruce750i's Avatar
11.02.2009, 12:03 PM
Originally Posted by kneedeeppow View Post
any ideas on how to stop my rcm pinions from getting eaten? motor and mount are solid(not loose) they pinion is meshed up nicely against the spur.i ran my 14t for 4 battery cycles and no problems.then today it got eaten along with a 15t pinion of mine on loan to another brushless truggy(this one completly stripped all the teeth)
Reading your description you use the words "against the spur". The two metal gears should mesh loosely to avoid any unneeded friction. Are you runninig your mesh too tight?
jsr
11.02.2009, 03:54 PM
I've bent one of Mike's mounts. They're made from 6061 T6 which isn't that hard to bend. I just took a plier and straightened. I have a metal spur also. Make sure your mesh isn't too tight. As suggested, spin the spur all the way around, several times and pay close attention to any point that feels a bit stiffer than others (ignoring the magnetic resistance from the motor).
jsr
11.03.2009, 01:23 AM
No idea if the Kyosho spurs fit. But regarding plastic spurs...I've had no problems with my plastic spurs. I prefer them as they run much quieter. Plastic spurs are thicker than steel ones to add strength. Make sure your chassis cutout has enough space for a plastic spur, otherwise you may have to do some grinding (I did).
ikpthegame
11.03.2009, 03:39 AM
even if they dont fit the cup just right all you need to do is sand down the cup a little on the edge. and yes they make very little noice. overall just a much nicer gear.
its me
There is no help for me... I'm addicted to R/C
its me's Avatar
11.03.2009, 04:14 AM
Last time i checked the kyosho diff cup is a larger diameter then the mugen by kind of alot.
rccna.com
kneedeeppow
11.03.2009, 05:08 AM
any ideas on spurs that would fit a mooge?
nuova faor sf501
