tkhoo
11.10.2009, 10:14 AM
Originally Posted by jas21373 View Post
My advice to you is Just DO it, But keep an eye on your temps.........Fieagos run hot ,Why not look for a secondhand Medusa????
Hi, may I know if the Feigao 9L run ~160F on a crt.5 do it consider HOT? Thanks.
jas21373
11.10.2009, 10:30 AM
I would consider that hot (160F=71C) ,my first conversion was with feigao 10xl and it cooked it self at at around the 180F/82C mark ,my Medusa's only see about 100/110F/38C-45C
hey mate you may want to start your own thread ,there's plenty of guys on here that have a lot of experience that can help you .
jas21373
11.10.2009, 10:36 AM
Originally Posted by fastbaja5b View Post
Mamba Max is a 3s ESC
running it on 5s =
my MM's have had 50+ 5s packs put through them ,geared right they have never failed me
tkhoo
11.10.2009, 10:37 AM
alright mate and thanks
coolhandcountry
coolhandcountry's Avatar
11.10.2009, 10:44 AM
160 sounds warm but not overly hot.
I hope it is kind of warm outside for these temps.
Peace!
Country
Help support the
Rc-Monster
Buy here
The Dan
The Dan's Avatar
11.10.2009, 05:58 PM
Maybe I should just do it, since this thread is generating some good debate on whether or not it will work. Problem is, I'm a cheapass and don't wanna spend $50 on a Zippy 5S pack.
I may end up just going with 4S/8XL. That worked well in my old E-Revo. Sure, the motor runs hot, but that's what my leftover HV heat sink is for. And I already have four 2S packs to play with.
jsr
11.10.2009, 10:10 PM
I think an 8XL on 4s would run fine. Just don't gear for too high a speed to keep your MM from cooking. Get dedicated fans for both the motor and ESC. Keeping the motor cooler will help keep the ESC cooler also. I ran my MM with a 6XL on 4s...much higher rpm. Great power and speed, but both ESC and motor got hot quick. Running it on 3s and not gearing it too aggressively would've probably kept it a decently running setup (not too hot). Good luck and have fun.
