MetalMan
MetalMan's Avatar
03.23.2006, 08:30 AM
IMO, that 1.5C "rating" has no significance. Lipos should not be charged at greater than 1C (unless otherwise specified). 1.5C is also not a way to measure current, unless there is a capacity thrown into the mix. But since there isn't, we can't make any assumptions as to the actualy charge rate (in amps).
squeeforever
squeeforever's Avatar
03.23.2006, 07:49 PM
well it does say, "up to 9999mah"
MetalMan
MetalMan's Avatar
03.23.2006, 09:29 PM
But that doesn't mean that it can do 1.5C at 9999mah. I think they say 9999mah because the LCD display can only do up to 4 digits, so batteries with capacity into the 10Ah range won't display properly when fully charged. I'll email MRC and ask what the actual charge rate is at different cell counts.
