Lipo cell count and charger
Tazz
Custom
Lipo cell count and charger - 03.17.2006, 10:58 AM
I just want to make sure I have this correct before I buy. A lipo battery 3s2p
would have a total of 6 cells, is this correct? If so I would need a charger that would be capable of charging at least 6 cells. If the charger was able to do 12 cells or more would I be able to charge 2 battery packs at the same time and if so would the 2 packs need to be connected in serial or parallel?
If this is possible what chargers are capable of doing at least 12 lipo cells?
Gustav
Gustav's Avatar
03.17.2006, 12:54 PM
Yes it has 6 cells total.The charger would see the pack as 3 cells of twice the capacity.You can charge these 2 packs in series as a 6s2p,6 cells as twice the mah.What Mah are the packs?.You'll want a charger with a good charge output,if they're high capacity,say 5.5amps or more.
Tazz
Custom
03.17.2006, 01:08 PM
So are you saying that a charger rated for say 1-6 cells would work to charge both packs at the same time. I was looking at 8000mah (each)packs.
Gustav
Gustav's Avatar
03.17.2006, 01:21 PM
I think so,wait for someone else to confirm this before you buy.8000mah!,that's going to take a while to charge unless you can find a charger with a very high charge output.Can i ask what the setup is,that sounds like an awful lot of runtime(and size and weight).
Tazz
Custom
03.17.2006, 02:33 PM
This is my previus thread for setup.
http://www.rc-monster.com/forum/showthread.php?t=2542
These packs are 44mm x 132mm x 39mm and are 495 grams.
What is wrong with runtime???
Gustav
Gustav's Avatar
03.17.2006, 03:14 PM
What d'ya mean what's wrong with runtime? Nothing.
Tazz
Custom
03.20.2006, 07:50 AM
Does anyone else know??????
Gustav
Gustav's Avatar
03.20.2006, 10:30 AM
It's definately right,i was just being cautious since it's your money.What charger are you looking at? To charge 8000Mah at 1C would take 8 amps,if you charge them at only about 5 amps,it's going to take ages to charge and you can't leave them charging unattended.
Tazz
Custom
03.21.2006, 08:05 AM
Here are some TP chargers I am looking at (charge and balance at the same time).
TP1010c - the problem with this charger is the specs state 10 amp up to 5 cells and 5 amp at 10 cells. I do not know what 6-9 cells charge at.
TP1080c - is not out yet but will charge 8 amp up to 7 cells.
TP1380c - is not out yet but will charge 8 amp up to 8 cells and 6 amp up to 10 cells.
The Super Brain 989 may be good but I do not know what the specs are on it and I do not think they have a balancer.
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
03.22.2006, 05:41 AM
Tower has some specs on the 989 here http://www2.towerhobbies.com/cgi-bin...?&I=LXLTW4&P=7
but according to them, it wont be available till "late spring early summer."
Tazz
Custom
03.22.2006, 08:09 AM
Johnnymaxxima I saw the listing at Tower Hobbies but it does not state amps per number of cells (example: 10 amps up to 8 cells). I am looking at some 6s 8000mah packs (2 3s packs charged at the same time on one charger). A lot of the chargers seem to drop the amperage after a certain cell count. I would also like one that can have a balancer hooked up so they can be charged and balanced at the same time. Do you or anyone else know of one?
squeeforever
squeeforever's Avatar
03.22.2006, 05:56 PM
i think a tp charger/balancer is your best bet. theres one supposed to come out that can charge 10s at like 9 amps i believe. its in another thread somewhere around here.
JOHNNYMAXXIMA
03.22.2006, 10:32 PM
I see the Charge Rate for the 989 says "1.5C max for Lithium cells"
What does that meen? Sorry for the rookie question.
squeeforever
03.22.2006, 10:46 PM
well the majority of lipos charge at 1c which is there capacity. so if there 4000mah you would charge them at 4 amps or 1c.
JOHNNYMAXXIMA
03.23.2006, 04:21 AM
Still a little confused. So when the description on the 989 reads... "Charge Rate: 1.5C max for Lithium cells" does that mean I can charge my 4000mah packs at 6amps? (1.5c X 4)
Sorry about the hijack Tazz.
