Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
pinkpanda3310
pinkpanda3310's Avatar
02.24.2010, 08:17 PM
It just occurred to me that it wouldn't be too difficult to make a new top plate myself.
Bare in mind if your going to use the larger spurs, the screws for the top plate from the motor mount run quite close to the spur.
nitrostarter
nitrostarter's Avatar
The easiest way to modify would be to simply shorten the legs on the existing top plate - I made the legs long enough and drilled and tapped the holes deep enough to allow this as an option. If you remove a known amount and move the mount holes for the front the same amount on the template, you have a smaller package that fits smaller diffs directly. :)
Ah, beat me to it... This was my suggestion as well, I just wasn't aware of how deep the holes are on the top plate and if there were tapped all the in.
N. Rustler conversion
Finnster
KillaHurtz
Finnster's Avatar
02.24.2010, 08:23 PM
4-5mm would probably be too far back for many diffs - there is less than 4mm difference between most diffs and a 3.3mm hole that is 4mm offset from another 3.3mm hole is practically a slot. :)
Hmm... yea, I'm not sure how much shorter your slipperential is, just a guestimate based on the pix and the shim recc's.
The other idea would be to make a second set of mounting holes offset from the first. It would be a bit more of a pita, as the F diff mount would need more work, but could span a range of sizes from the long diffs, to shorter ones like the SlipDiff w/o tons of shims.
IDK, just a thought. I'm sure you will come up with something clever. :)
Here's a crappy pic of what I mean.
Name:	top plate.JPG
Finnster
KillaHurtz
Finnster's Avatar
02.24.2010, 08:24 PM
^^^ and that would be it lol
02.24.2010, 10:45 PM
can anybody link to shims to center the diff in the mount? They nhave to be narrow enough to allow the drive cup to pass through and I can't find any
jhautz
jhautz's Avatar
02.24.2010, 11:32 PM
Maybe use a 16mm OD o-ring as a shim.
to make it...
or break it...
Silent...But Deadly
adrictan
02.25.2010, 06:50 AM
I used these.
http://casterracingusa.com/product.p...7&cat=0&page=1
02.25.2010, 08:06 AM
Originally Posted by adrictan View Post
Thank you!
JThiessen
JThiessen's Avatar
02.25.2010, 10:36 AM
I was thinking from the perspective of a completely custom installation. If someone was making their own chassis and such.
Mike, do you have the dimensions on the slipperential? Ie. bearing to bearing distance? I'm doing a custom chassis and plan on using the slipperential. Would be very beneficial to have this info prior to machining........
02.25.2010, 03:39 PM
You could also make the top plate shorter and have a few different spacers included to space out for longer diffs?
bdebde
That's All Folks!
bdebde's Avatar
02.25.2010, 04:10 PM
Seems easy enough to just cut the "legs" of the top plate to distance needed; I like it.
nitrostarter
02.25.2010, 04:37 PM
Thats what the big man suggested
Kcaz25
Kcaz25's Avatar
07.28.2013, 07:32 PM
Thank you!
Hey Harold, this link doesn't work anymore. What do I need? Linky?
Thanks,
Zach
07.29.2013, 02:05 AM
Thanks,
Zach
You need 13x16 shims. Here's some on the bay> http://www.ebay.com/itm/Kyosho-13x16...item3383e5d17b
