UE Supermaxx Addict!
05.15.2010, 04:23 PM
Originally Posted by Muggydude
How do you like the tranny locked in 2nd without the mechanical brakes?
I absolutely love it! With the instant power and massive torque of brushless motors, 1st gear is literally useless, it's just so low and the BL motor spools up so fast, the transmission shifts in less than a second, and having the 2-speed intact seriously weakens the transmission. The torque of the BL motor IS your first gear, so the mechanical 1st gear in the transmission is not needed.
The mechanical brakes, to me, are just plain useless on any electric/brushless vehicle. The ESC & Motor are far more efficient as brakes, as well as being far more adjustable. Not to mention that mechanical brakes fade and wear out...ESC/Motor brakes NEVER fade and NEVER wear out, PERIOD!
did you ever have the mechanical brakes
Nope...as soon as I did the brushless conversion, the center-diff and both front & rear brakes went bye-bye!
and how does it compare?
There is no comparison...like I said, the ESC/Motor brakes are far more adjustable, NEVER fade, and NEVER wear out.
what gearing do you have on it?
38T Mod1 Spur, 17T Mod1 Pinion, 14.8V, 0.25" Ballooning, 42.08MPH. Calculated using BrianG's Speed Calculator.
I'm trying to decide if I should switch my Tranny into second instead of the 2 speed.
One of the best things you can do is lock the transmission into 2nd gear...it not only makes the transmission MUCH stronger and MORE durable, the parts you remove reduce rotating mass for faster acceleration and top-speed. Like I said, 1st gear is useless in a brushless setup, so you might as well go ahead and remove it now, and make your transmission stronger and more durable.
-Chad
› PM ME IF YOU HAVE THE BELOW:
› VBS, CVDs, GM Single-Speed, OTB, Ultramaxxed, Super6, Strobe, Sprong, CNR Brake, UE Hex, DUH Towers, Predator, Blackbird, GA Blue Screws, HCR F/R Skids & Mutant
05.15.2010, 04:26 PM
Originally Posted by - SmashBash -
Wow.. Nice Revo convert. Do you have a Item-No on that Harddrive body from PL? Want it on my E-Revo ;)
Unfortunately, PROTOform (Pro-Line) discontinued it, so it is getting very hard to find. I don't know the part number, because I no longer have the header-card from the bag the body came in, but it is just a PROTOform HardDrive body for the Revo 3.3.
-Chad
05.15.2010, 04:50 PM
Oh..
okay thanks alot.
Think i found it here http://shop.towerhobbies.com/cgi-bin...&P=WR&I=LXTJB9 :)
05.15.2010, 07:46 PM
But you can't buy it :( Look on ebay or amain. I alos like the hardirve too. Thanks for the help Chadworkz! Now here's my question for you. Right now I have the MMM 2650kv motor with Turnigy 4s 5000mah 40cs. Think I'll still be able to pop soime wheelies without the first gear? I was alrerady thinking about taking out the 2nd gear because I don't really like the mechanical brakes, the ESC sits way too high (I'm going to move it to where the Brake servo used to sit, and it will shave off some weight. Think my gearing off 16T pinion, 36T spur, and close ratio second gear will be a a good setup? Right now it goes about 45 m.p.h. as it sits.
05.15.2010, 11:17 PM
Look at the stock status, it's discontinued, so you can not order it, and you can't back-order it, because they don't have any more at all.
First, get rid of that 2650kV and get the 2200kV...the 2650kV is a buggy motor, and does not do well in truck/truggy/monster truck applications...it can actually cause problems, like taking out the ESC. The 2200kV is a truggy motor, producing much more torque and power, and is exactly what you need in a truck/truggy/monster truck.
You DO NOT want to remove 2nd gear, you want to lock the transmission into 2nd gear and then remove the 1st gear components. 16/36 is decent gearing, but you really need to swap that motor for the 2200kV motor. I personally run standard-ratio, but you can run whatever you want...close, standard, wide, whatever (but I recommend standard).
-Chad
05.16.2010, 01:28 AM
Cool, I guess I'll try to sell that motor and get the 2200kv. I actually boguht this truck with, it wasn't my choice. Adn I ment remove the 1st gear, not 2nd.
05.16.2010, 07:10 AM
Its out of stock on amain too, but CML do have it in stock- grab it quick!
05.16.2010, 12:03 PM
The 2.5 version is much too short for a Revo 3.3, and waaaay too short for an E-Revo, so it won't fit at all.
-Chad
05.16.2010, 03:48 PM
Maybe my LHS have some Harddrive in stock. If not, i may use the PL Slipstream.
But I think the Harddrive looks so mean with all that scoops, and the headlights! :) hihi
05.16.2010, 07:18 PM
Got some good interest in selling my 2650kv motor today. What do you think about this gearing? Wide 2nd gear, 36T spur, 17T pinion, 2200kv mtor, 4 cell lipo, and badlands tires? Top spped shoudl be about 45 m.p.h.
05.31.2010, 06:11 AM
-Chad
n00b
05.31.2010, 09:52 AM
Habba habba  nice work!!
Mugen MBX6Te RCM + Mugen MBX6e RCM + Savage Flux XL FLM + MERV all with Spectrum DX3S || WTS& WTB
05.31.2010, 10:44 AM
Man now thats nice job Almost like the one I did LOL I dont have those skill yet nice awesome work
- RCM XT8 MMM NEU1521 1Y AKA TIRES HITEC 7955 TG 6S
- MBX6T MMM CC 1518 HITEC 7955 BRAKE 5645 MG 6S LIPO
05.31.2010, 01:59 PM
Sweet!
R.I.P. Muggy, Rustler, VXL Slash
EFlite Blade MSR Heli (Slightly modded)
1/16 BL E-revo
8-t 2.0, OS Vspec with Speed conrod
Carbon Fiber Revo 3.3 Coversion Madness!
