Removed everthing and installed the Slash 4x4 RPM front bumper the two holes match perfect!
Click on the pic to make it bigger!
Next are the 12mm hex drives for adding the neg. 10* Proline Protrack Wheels to get me to the desired legal with: http://www.impaktrc.com/product_info...oducts_id=5655
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
NEED SOME INPUT... WHAT DIF OILS ARE YOU USING? AND GEARING? I want to use a GTB / 4.5SC Tekin combo on 2's.... had to take a break and i'm going full force again! I need a Conversion!
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
Great job! What body did you use? I thought the Ten-T wheelbase was about 1.5" shorter than most SCs, but that body seems to fit the conversion perfect.
I picked up a used roller and have been planning on converting but couldn't decide whether I wanted to convert it to a short course truck.. you say you flipped the A arms? what did you do and why?
