simplechamp
simplechamp's Avatar
08.16.2010, 11:53 PM
IMO it's fine to test a motor with no load on it, you just have to use common sense. Of course pinning the throttle and holding it wide open for minutes will cause problems, but doing short tests at low to mid range throttle for a few seconds at a time isn't going to harm anything.
scarletboa
scarletboa's Avatar
08.17.2010, 02:40 AM
+1
running a motor with no load won't turn it into a grenade
Dont panic
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Dont panic - 08.17.2010, 04:04 AM
Yea I do not see any reason to panic about this. Testing a motor of any kind with no load is a fairly common practice in industrial areas. I am sure that most motors are under rated as to their true top RPMs, so you would never want to wind any motor out without being attached to something. The outcome could be catostrophic to the motor and even dangerous. The sound you were hearing was directly related to the fact that you were running it in your hand. Most likely the motor is fine.
SUPERMAXX YOUR LIFE.
nuz69
nuz69's Avatar
08.17.2010, 04:24 AM
+1
Running a motor without load at full throttle won't do any damages...
Thoses NMB bearings are rated for up to 100 000 RPM, so there is no way you damaged it on a no load test.
I personnaly tested a CC 2200Kv motor and other CC motors at full throttle and no load during minutes, and there was absolutely no problems, the motor seems the get warm quickly (40°C) , but it's because it's in your hand at 34°C and it can't cool itself with air flows like it does normally in your vehicle...
So stop panicking when you see someone testing its motor with no load...
More over it drains ~2-3 amp during no load test, so what's the risk guys ??
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Pdelcast
Pdelcast's Avatar
08.17.2010, 11:12 AM
+1
It's fine to run for a few seconds with no load. Just never run an extended period with no load -- the motor will overheat quickly with no load.
The 2200Kv motor will be quite loud with no load. Remember, the RPM is EXTREMELY high with no load -- it will make quite a racket. :)
-Patrick
Patrick del Castillo
President, Principle Engineer
sabongi
08.17.2010, 12:46 PM
Absolutely, but what kind of noise?
AFAIK would be a loud whine, right?
Not grgrgrgrgrgrgrgrgr
Stoomstrijkijze
08.18.2010, 11:54 AM
Make a movie with good sound and upload it on youtube. Then post the link here.
