Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
sikeston34m
sikeston34m's Avatar
04.17.2011, 06:40 PM
I took this setup for it's first run today.
First, a watt meter was connected to the SLA batteries to get an idea of what was going on there. I was shocked.
On high, the trolling motor was pulling 27 amps, but the voltage was sagging to almost a flat 9 volts. Sheesssh......
I'm not sure if my wiring sucks or if the SLA batteries are in that bad a shape.
But then came the better results.
After being hooked up to the converter array, Running the trolling motor on high resulted in alot more power.
Todays run on the watt meter produced the following results:
12.64 voltage minimum
50.11 amp peak
633 watt peak
65,500 mah consumed for the day
The single packs of 18650's performed very well. Their voltage sets right now at:
#1 - 3.77
#2 - 3.76
#3 - 3.77
#4 - 3.76
#5 - 3.77
#6 - 3.76
Very balanced and quite powerful. The end of the day's run being just as powerful as when the pack was topped off.
My wife and I ran all over the lake today and the battery still has alot of juice left.
This pushes the boat with alot more power and top speed is much better too.
J57ltr
04.19.2011, 07:46 PM
Wow, cutting it a little close huh? Those are great results
Jeff
sikeston34m
04.19.2011, 08:50 PM
Jeff
Thanks.
a little close? Oh. The 65,500mah consumed? Here's something strange.
Since that's on the low voltage side of the setup, you can divide that by 2 to get the mah drained from the 6S pack.
Total pack mah came out to be a little over 72,000mah. I used some new 2600mah cells also.
She should be good for about 126,000mah+ on the low voltage side considering efficiency losses.
I want to add a true sine inverter to use this as a backup battery for power outages also.
The charger has added 27,000mah back to the pack so far and cell voltage is just now up to 4.0 volts per cell.
I'll get the total and figure up the eff. loss percentage. It should be 10% or less.
sikeston34m
04.20.2011, 11:44 PM
The 180 cells that make up the 6S pack, took back 45,000mah to become fully charged again.
Whew! I need a bigger charger. LOL
This means all day fishing used 63% of the pack's total capacity.
Now we have enough data to figure efficiency losses.
The watt meter measured 65,500mah worth of useable energy going to the motor.
On the high voltage side, this translates into 32,750mah of energy
Hmmmm..........73% total efficiency. That's not very good really.
I think a large amount of the losses came from the wire that I'm feeding with. 10Ga. Silicone does get warm when feeding 50 amps continously for extended periods of time. The wire was probably 95 degrees on a 70 degree, fairly windy day.
Traxxas High Current connectors are used to attach the silicone leads to the trolling motor lead. I noticed the trolling motor lead was a little warmer than the silicone portion of the lead Entire lead length is about 7 feet.
Hmmm........perhaps replace the entire harness with 8Ga. Silicone.
I could detect very little heat coming from the converters.
This pack does still serve a good purpose and I'm looking forward to the fact, this setup could live and give for 10 years.
sikeston34m
05.10.2011, 06:21 PM
I forgot to show the almost completed version.
This picture shows the 5 - 200 watts Vicor Converters wired parallel. 1000 watts of power at 13.8 volts DC.
The parallel hookup was interesting. One of them is the brain of the operation and the rest are booster slaves.
I still intend to add a true sine wave AC inverter to help things when the power goes out.
I did add an outlet to the outside of the box which will channel AC power to the outside. The switch you see, disconnects the 6S pack from everything.
05.11.2011, 11:16 AM
You need to go up to at least 6mm bullet connectors, and maybe larger. I saw that you are using 10gauge and 4mm connectors. 4mm bullets are not big enough. Plus you need the good bullet styles, like castle sells.
Also, reduce wire length wherever possible. Even an inch here and there translates to alot of un-necessary wire.
Looking good, glad you are having these great results!
J57ltr
05.11.2011, 12:32 PM
Go to at least 8 gauge or even 6, for a draw like that on 12V. Earlier I misread I thought you had a 66ah pack.
Jeff
sikeston34m
05.11.2011, 06:40 PM
It's funny how voltage goes through the converters.
Watts in = Watts out
What I mean is, if I'm drawing 50 amps on the low voltage side, on the high voltage battery side, it's only 25 amps.
I figured the 4mm bullets and the 10Ga. would be enough for that.
It's on the low voltage side that I really need to increase the wire size.
I verified all of this with a watt meter.
It's funny you mention the wiring thing though.
Last time we went fishing, I forgot my 7 foot 10Ga. "extension cord".
This forced me to move the power alot closer to the motor.
Voltage drop was less and total watts was considerably more.
I need to go bigger between the converters and the motor for sure.
sikeston34m
05.11.2011, 06:41 PM
Jeff
The pack is actually over 73 ah.
I put some new Sanyo 2600mah cells in parallel also.
I kept the count equal on everything of course.
captanabolic
captanabolic's Avatar
05.23.2011, 01:59 PM
Hello All
I am also looking into some alternate battery power for my TORQEEDO 801 I need to come up with a pack maybe some of you battery guys can help me come up with a solution:
Motor specs:
http://www.torqeedo.com/uploads/medi...english_07.pdf
LIMA high-performance battery with integrated display of charging state,
300 Wh, 29.6 V, for use with BaseTravel 801
replacements go for about $500. the newer models have a 480 Wh (Watt Hour?) Lithium magnese (LIMA) any suggestions or improvements would be greatly appreciated. I have a adapter that allows me to use 2 12v marine cells. (heavy) My goal would be to make a 10 pound batt. their batt is 7.7 pounds.
http://captanabolic.onestop.net/drift_manga.gif
FAST ENOUGH TO DO SOMETHING STUPID
REALLY STUPID
THE CAPT IS SOOO SEXY!!!
HOLY HOLE IN THE DONUT BATMAN!!!
captanabolic
05.23.2011, 02:25 PM
also would this be correct:
Divide the energy storage capacity of the battery (watthours) by the battery voltage (volts) to get Ah (Amphours). Multiply by 1000 to get mAh.
So the original battery:
300 wh x 29.6v
=10.135 x 1000
= 10,135mah
so i would need a 10000 mah 29.6v pack to equal the old power supply.
confusing lol
REALLY STUPID
Bmr4life
05.25.2011, 01:36 PM
Whoa, that's over $1000 in batteries.
05.25.2011, 03:22 PM
300 wh x 29.6v
=10.135 x 1000
= 10,135mah
confusing lol
Unless Im trippin' that seems correct- you'd only need a couple 5,000mah 8s lipos in parallel it seems ( or 4x 4s 5000mah packs, wired up to get the same result ).
Depending on the brand and discharge ratings, you could build a suitable pack for as little as ~$400, though more like double that for a premium brand of battery say.
Would be interesting to have a watt-meter hooked up between the controller and batteyr to see what peak/ max current draw currently is...
pinkpanda3310
pinkpanda3310's Avatar
05.25.2011, 07:02 PM
Generally speaking 18650's can put out 4-5 amps max continuously (single cell).
sikeston34m
05.25.2011, 08:19 PM
Yes, that's why if more power is needed, you can always parallel cells.
My Power pack's output voltage is nice.
Our power just went out during a bad thunderstorm. This pack powered an inverter, which in turn power a 32" flat screen TV.
This way I could keep an eye on the Radar.
