06.17.2011, 09:28 PM
Try to beat 124 mph  someone else on youtube hit that with a tc4
06.19.2011, 11:44 PM
is a different scale ........ 1500gr with body vs 4000gr without body is a very big difference ........ if I use this electronic in a touring 1/10 and dont break/destroy the transmission provably I will pass this speed .....
SWORKZ BE-1, LEOPARD, HOBBYWING, GENS ACE, SANWA VX, FUTABA 3PL, MBX5R/T, RB5SPSL, FG MONSTER, TC5R, 808E, HYPER8, TF5, ZX5, NANO-TECH, HYPERION, 620DMG, ECO6-10, TEAM-IHOBBIES
06.20.2011, 04:04 AM
A 1520/1Y 1600Kv should be better appropriate ? It hold high RPM better than the 1717. Anyway, good-luck and keep us posted !
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
06.20.2011, 02:42 PM
thanks ..... provably first I will use a leopard 4282 2000kv +9s ...... and If I dont have the necessary power I will try with the 1717
06.21.2011, 05:07 AM
The Castle 1520/1Y is longer (handle more power) than the leo 4082 and with its lower Kv, you should even use it in 10S
07.01.2011, 10:56 AM
same car ..... but different setup ..... in a track
http://www.youtube.com/watch?v=Sz-uoJ1luHc
08.01.2011, 07:05 PM
first tests .......... 106mph ....... vid:
http://www.youtube.com/watch?v=uqPWNlZ5cgQ
08.02.2011, 09:05 AM
Pretty nice  ! What is the 4282 motor Kv ? The drive train makes an awful noise. Did you shim your diffs  ?
08.02.2011, 05:40 PM
thanks ..... is a leopard 4282 2000kv .......... when I brake the noide is because the front of the body rub the asphalt ..... all the diffs are perfect
soon more tests with 10-12s
11.14.2011, 03:32 PM
11.14.2011, 04:01 PM
Wow :D You 've done it GREAT :D Do you know there is the leopard 4092 now ? 485g and more power than the 4082 :D :D
11.16.2011, 01:47 PM
of course the 4092 will be much better .... but sincerely my most important problem are the tyres ....... is very easy break the tyres at +110 mph :(
thanks
Originally Posted by tech_freak
I will try in future tests ..... thanks :D
11.16.2011, 09:38 PM
Thats what I have on my GTP but they don't grip that well, the back end is very loose.
