sleepy23
sleepy23's Avatar
04.11.2005, 09:31 PM
i am just telling you what the system says. everything is calculated based on the spur, pinion, and tire diameter you type in and the the signal from the sensor. i know how to type in numbers and i have digital calipers to measure diameter, so i post what it tells me, until someone with the Exact same truck does a run and posts a different speed, i do believe mine stands. i also am talking about straightline speed on road with a highly modified truck and a one of a kind custom tranny.
S^3: everyone wishes they could design modifications like these.
gixxer
gixxer's Avatar
04.11.2005, 10:44 PM
what the system says is fine. getting your motor to actually pull that gearing is the problem. i had a t4 with the novak 5800 and it was not even close to those speeds. i would say 37-38 on 7 cells. http://www.teamnovak.com/Download/ac...pecgearing.pdf look at the bottom, also that is based on 6 cells, for 7 you should gear even lower.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
sleepy23
sleepy23's Avatar
04.11.2005, 11:07 PM
i took the truck out with gearing that pulled 48mph and it ran like mad. i didnt have my recorder in it to check the speed, but i guess it doesnt matter much now as i will be putting my new system in and see how fast it will run.
Dafni
Dafni's Avatar
04.12.2005, 02:21 AM
Okay, here are my Revos numbers:
Motor: Feigao 9L
ESC: BK 9918
Cells: 14 GP
Spur: 66
Pinion: 16
Tranny: EMaxx
Diffs: Revo (same reduction as Maxx)
Wheels: Maxx sized
Guesstimated speeds:
1st gear: A bit more than 20mph
2nd gear: A bit less than 40 mph. But more than 35, I think.
Sorry for the inaccurate speeds. I have no possibility of measuring accurately. But I think those are good guesses.
The temps are fine, I still think I could add a tooth or two on the pinion.
