Hustler
Hustler's Avatar
07.06.2006, 02:43 PM
Originally Posted by neweuser
Is there an easy way to tell about the fet's?
Hustler: It would run way tooo hot!
What if you used a 8xl with like 14 cells in your setup..!!! Would it still run too hot..!!
I hope, you dont feel I am threadjacking, just trying to get a feel and some knowledge of different combinations and their output speed etc.
neweuser
neweuser's Avatar
07.06.2006, 02:50 PM
An 8xl on 14 should be fine...
Hustler
Hustler's Avatar
07.06.2006, 03:10 PM
But would it reach the speed you are aiming for..??
neweuser
neweuser's Avatar
07.06.2006, 03:15 PM
That I'm not sure. Someone with more experience with those motors could probably spin in and give accurate info on that one. LOL
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
07.06.2006, 03:21 PM
Here are the diff ratio's for you...
Diff ratio’s
Stock- 2.85:1
UE 1/8th - 3.31:1
and squee I've been running my 1920/8 ot the rpm range of 56433.6 RPM for over 4 years and I've never had a issue with it overheating or anything....for me to run it at 40,000 rpm I would only be able to run 8 cells and that's it...
neweuser
neweuser's Avatar
07.06.2006, 03:24 PM
Now now children, no fighting on the forums...I give you both 5 warning points! LOL, j/k! Thanks for the ratio's. What do you guys think of the 1930/10t with the quark set up on 16 cells?
07.06.2006, 04:50 PM
Diff ratio’s
Stock- 2.85:1
UE 1/8th - 3.31:1
Thanks for the ratios. Can you tell me the pinion and spur tooth count on those UE's? I want to add it to my speed calculator. To keep the precision as high as possible I don't round answers at all until the final output.
sjcrss
sjcrss's Avatar
07.06.2006, 04:57 PM
not with out having to take my diffs apart, these ratios are what was posted on the UE forum
neweuser
neweuser's Avatar
07.06.2006, 05:03 PM
You could ask Robin on the UE forums???
07.06.2006, 05:09 PM
That's OK, I'll just use a 3.31T spur with a 1T pinion. :)
sjcrss
sjcrss's Avatar
07.06.2006, 05:11 PM
thats funny....i like that one...
neweuser
neweuser's Avatar
07.06.2006, 05:54 PM
Well, i'll hold my comments as well, but yeah good stuff! I'm still curious though. i wonder what the tooth count difference from stock and UE is?
coolhandcountry
coolhandcountry's Avatar
07.06.2006, 05:56 PM
The ue has 43 on the spur with 13 on the pinion.
The hb pro gears are 43 on spur 10 on pinion.
Peace!
Country
Help support the
Rc-Monster
Buy here
Hustler
Hustler's Avatar
07.06.2006, 06:42 PM
Would the hb work well with a 7xl or 8xl motor..!!! and what kinda speed..??
neweuser
neweuser's Avatar
07.06.2006, 07:06 PM
So basically if you change the pinions, would almost be like stock? What does stock pinions run?
