standard_63
standard_63's Avatar
07.26.2006, 08:45 PM
I've been able to get most replacement parts for the T2 from Tower, and the others thru Associated. So far no problems, but handlingwise I'm sure the newer designs are better.
Please tell me that's not smoke I see!
stampy
stampy's Avatar
07.27.2006, 04:59 AM
Originally Posted by nbcaznmaster
i got a t4 if your intersted. Also, i dont think the the rustler was such a great deal...
really :032: a hopped up rustler with motor and esc plus parts truck stampede with the same esc that also has some goodies i though it was a good deal :002:
MetalMan
MetalMan's Avatar
07.27.2006, 10:17 AM
IMO, it was a good deal. Back three or four years ago I got my Rustler with ESC (XL-1) and a cheap charger and battery for about $150 on Ebay. What you got is more than that.
stampy
stampy's Avatar
07.28.2006, 06:27 AM
i noticed that it says RRP hardened gears in gearbox for the rustler i went to there site and they dont list them so they must be discontinued. what gears is he talking about? spyder gears (sun gears in rc talk) maby or what?
MetalMan
MetalMan's Avatar
07.28.2006, 10:40 AM
They're the planetary (sun) gears inside the differential. RRP stopped making those probably about 2 or 3 years ago.
stampy
stampy's Avatar
07.29.2006, 12:12 PM
are they any good, well better than stock?
camel_rc
07.29.2006, 03:10 PM
Anything would be an improvement over stock. From my experience with my stampede a couple years ago, the stock were complete garbage.
Superbasher
Superbasher's Avatar
07.30.2006, 05:42 AM
there is one thing that annoys me about the T4. the transmission is bulletproof (touch wood) and has not given me any trouble in all the time ive owned it, no matter what i did to it. at one point it got a bit creaky after a hard knock, but i tore it down, and that solved that. now the chassis seems to be alot weaker. i did a small jump, it flipped and snapped the rear shock tower and broke one of the rear body mounts.
  Send a message via MSN to Superbasher
Rtsbasic
RC-Monster England!
Rtsbasic's Avatar
08.03.2006, 01:51 PM
Strongest new one is probably a Rustler..or if you don't mind a bit of work, a converted RC10GT. I've done two conversions, and its my fav vehicle because its so durable but still handles pretty well.
But by far the strongest car I've ever owned is an RC10T2. With a few key upgrades (that are easy to get thanks to RC10GT compatibility) its never really likely to break. Infact in several months of running all I've done is loose a couple of rear body posts, snap a screw in an arm mount (it drilled out fine) and trash two bodyshells.
  Send a message via Yahoo to Rtsbasic
stampy
stampy's Avatar
08.04.2006, 02:05 PM
ouch!!:036: stupid plastic top gear wtf i though they came with steel ones stock:002: and whats with the black diff arnt the stock ones white :032: atleast when i opened it up i seen a alum idler :027:
ID:	1517   Click image for larger version
seth556
RC-Monster Silicon Carbon
seth556's Avatar
08.04.2006, 10:27 PM
Traxxas says to use a plastic top gear when using an alum idlear but that dosent really make sense to replace one weak point with another.
  Send a message via AIM to seth556
