Serum
Serum's Avatar
08.04.2006, 10:55 AM
if i recall correct, 1 hp is lifting 70 kg 1 meter high, 1 meter far in 1 second. now thanks to our metric distortion.. grab a calculator.. :P
Nick
COOKIES!
Nick's Avatar
08.04.2006, 07:26 PM
I read that about 4-5 times but still didn't understand Serum. :D
Intresting thread, a good read, thanks.
~ Nick.
08.04.2006, 08:37 PM
In simpler terms (maybe); horsepower is how fast you can lift 70kg up 1 meter high.
If you have 1HP, you can do it in 1 second.
If you have 2HP, you can lift 70kg up 1M in 1/2 second.
Or, if you have 2HP, you can lift 140kg up 1M in 1 second.
Or, if you have 2HP, you can lift 70kg up 2M in 1 second.
And so on.
Although, saying you have to move "up" seems to take gravity into consideration...
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
08.05.2006, 04:10 AM
Does anyone know if XRC has dynoed CEN's 7.7 engine? I believe they (CEN)clame 5hp for that engine. That is a huge engine but still seems like a lot a power.
08.05.2006, 04:20 PM
Don't know, but any Nitro motor will put out that HP for a small rpm range. Above and below that range, the HP will be substantially less - especially at the low range where you need it most.
cemetery gates
08.05.2006, 04:49 PM
If I remember correctly it was like 1.56 hp and .59oz. of torque. Definitely NOT 5hp.
crazyjr
crazyjr's Avatar
08.05.2006, 10:04 PM
Originally Posted by pb4ugo
Nothing theoretical about it (except some manufacturer's claims).
1hp=33000ft.lbs/min
The ability to do work over time.
Sorry, i wasn't clear on what i said. On 1 to 1 dyno's, the rpm and torque are the only things actualy measured, Hosepower is calcutated in the computer. The theoretical part comes in with how the car is setup, you can have a camaro that makes 300 hp on a dyno but with the proper setup can show more power at the track than it showed in the dyno room.
squeeforever
squeeforever's Avatar
08.05.2006, 10:10 PM
Such as airflow.
coolhandcountry
coolhandcountry's Avatar
08.06.2006, 08:40 AM
The dyno registers how long it takes to produce the rpm with a certain resistance.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
08.06.2006, 10:54 AM
I looked it up, 1 hp is moving a mass of 75kg 1 meter per second UP (1m/s is 3.6km/h is 2.25mph)
Bolt_Crank
08.06.2006, 05:20 PM
Not sure who originally said it.. I think it was Carol Shelby, but..
"Horsepower sells cars, torque wins races."
Bigger number, in a unit almost everyone has heard of, is going to sell more.
crazyjr
crazyjr's Avatar
08.06.2006, 07:28 PM
Jack Roush has been known to say that to
