Caine
02.28.2007, 02:06 PM
what does a sway bar do?
what brushless motors and if you have lipo what lipo are you guys/gals running in ya t4s?
oh and if your have pics of your t4's dont hesitate to post em.:027:
02.28.2007, 04:04 PM
A sway bar loosely couples the suspension on both sides of the vehicle to help reduce body roll and can be "tuned" by using stiffer bar stock. You don't want it too tightly coupled or when one side articulates over a small bump, the other side will too.
You can see it working by picking up a car (so it's off the tires) with a sway bar setup. Push up on one of the wheels. Once you get to a certain point, the sway bar will cause the other side to raise as well, just not as much.
Sylvester
Sylvester's Avatar
02.28.2007, 05:07 PM
And i have noticed that in my lsp i prefer running rear sway bars only, the front sway bars are not the greatest since it give the truck this weird feeling.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
jnev
jnev's Avatar
02.28.2007, 07:31 PM
The Mamba Max as many others will say as well, will be great in your t4 mainly because it is so programable. As for lipo, I am also still learning about these kinds of batteries, but the Max Amps 2s or 3s 4000 packs seem to be doing well for many people.
Sylvester
Sylvester's Avatar
02.28.2007, 07:34 PM
Im running 2s2p 8000mah maxamps lipo in my B4.
Losi 8ight e
Caine
02.28.2007, 09:16 PM
how does the s in 2s mean cell except its not spelled cell but its spelled "sell"?
And much runtime you get off that 8k in ya b4 for alot of full throttlin?
glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.28.2007, 09:39 PM
"2s2p"
the s means series
the p means parallel
It describes how the pack is constructed... what the voltage is, how many total cells are in it, etc.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Caine
03.01.2007, 08:28 AM
ohh alright thanks lol i thought it always meant cell.
Do most people run setup sheets or do they just run what they think is good for the track?Because I asked a guy if he used a setup sheet and he said he uses his own tweaks and stuff.( This guy being one of the better guys at the track)
Caine
03.09.2007, 04:44 PM
could I safely run a 7.4v or 2s lipo with a novak 5.5 gtb combo?
Sylvester
Sylvester's Avatar
03.09.2007, 05:02 PM
No problems on running 2s in the GTB..
Losi 8ight e
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
Talking 03.09.2007, 05:31 PM
look here for setups:
http://www.rc10.com/racerhub/setup/0...oad.htm#RC10T4
try to find one where the surface and lay-out match the track you'll be racing on.
also try to match the power-output somewhat if you know what i mean by that.
losi 8ight-t
xray xt8
