05.30.2007, 02:16 PM
Yes... ESC mounted to the flat side and the fans on the other. There are screw holes to mount dual 40mm fans on the finned side of the heatsink.
The nice thing about the mount is that its thick enought that you can add extra 3mm screw holes anywhere you need them to mount it anywhere you need it. Ive added screw hols in a couple of mine to make for clean and simple mounting.
I have fournd that the thermal epoxy isnt needed. Arctic silver thermal paste and a couple zip ties do the trick for me. Once the arctic sliver sets after a week and creats a soft bond to help keep it from sliding around also. But the zip ties have been enough for me.
Mounting the fan under the chassis plate is convienient, but the fans dont last very long mounted top side down like that. One big jump and the blades pop right off. See if you can come up with a configuration that puts the fans on their side. or at least at an angle rather than flat.
to make it...
or break it...
Silent...But Deadly
05.30.2007, 02:23 PM
thanks Jhautz, I was figuring a couple washers under thwe fans would allow some movement of the fan blades without contact
05.30.2007, 02:33 PM
Its not the contact on the plate that the problem. Tha fan baldes are only pressed onto a shaft and when you land the fan blades pop off from the force of the landing.
to make it...
or break it...
Silent...But Deadly
05.31.2007, 12:34 AM
Originally Posted by Cartwheels
Thank you Cartwheels, Do you know if JB Weld will work? I got it handy and use it for everything
Edit; Never mind, I checked and it contains iron powder and will not work
05.31.2007, 11:31 PM
they came in today and look smaller than i thought, they look big in the pics. I guess pics add 15 pounds after all, too bad its not in good heatsink;). while i wait for the heatsinks, I will try one on the esc plate i made for the revo with Emaxx tranny. play around with settings and light driving and see how it does. thanks for the advise guys. Next question, What Neu motor should i get? My Gmaxx has UE diffs and a slipperential, my G2R has an EMaxx trannywith steel idler and upgraded stock diffs. My aim is for bashing and racing with speeds comparable to nitros
05.31.2007, 11:40 PM
I assume you'll be running 4s? If so, the 1512 2.5d (kv=2000) or 1515 with a similar kv; like the 1515 1y (kv=2200) or the 1515 2.5d (kv=1700).
05.31.2007, 11:47 PM
well, I want one that is a little flexable. I will start at 4s for tests and till i get the heatsinks, probably stick to 4s for racing, But i'd like to go 5s every once in a while for kicks, probably stick to 4s mostly though
Actually two motors, but not sure how the difference in the two trucks will effect motor selection
05.31.2007, 11:50 PM
Then get the 1512/2.5D. (2000kv) Great on 4s for the track and can easilly handle the 5s for bahing with a llittle more speed.
to make it...
or break it...
Silent...But Deadly
05.31.2007, 11:54 PM
thanks, can it be got with a smooth can? I got one truck with a transmission and don't want to dremel a 240+ motor
05.31.2007, 11:57 PM
You'll probably have to email Mike for a smooth can 1512 2.5d. If he doesn't happen to have one laying around, he'll have to order it...
05.31.2007, 11:58 PM
ok thanks, sounds like the motor i need. now to order up
06.01.2007, 01:05 AM
Yes they come in smooth can and shouldnt be that hard to get. I have 2 of the 1512/2.5d motors, both of them are smooth can.
to make it...
or break it...
Silent...But Deadly
06.01.2007, 06:14 PM
I wasn't sure exactly which to get so got both and figured i'd ask before using them. One is called super thermal silver compound, and the other is called high density thermal compound. The super thermal is called artic silver 5, and the high density is called cramique. I was just wondering which i should use.
I also found these and was wondering if they will work on the side of the Quark esc? http://www.radioshack.com/product/in...tId=2216875&cp If not, no big, but thought they might help. and last Question before i start, I was looking at the instructions and see in the hard lipo and normal lipo the cutoff is 2.7v per cell, to change it you need to go to manual and that will mess up using the normal lipo. Will it be ok on 2.7v per cell
06.03.2007, 11:20 PM
got one of the quarks running in the G2R, just set radio to esc and tested to see if it would run good. WOW!!!! it seems to have more power than the mamba, I crushed a diff in 5 minutes, it was upgraded with integy cups and cases. Since the upgrade i have hammered it hard and they seemed good, till the quark. I am running the same setup as with the mamba, 9XL and 5s, I didn't set anything except for the esc to radio. I am impressed, All i need now is the rc monster heatsink, a V2 slipperential and a set of 1/8 diffs and she'll be perfect. I may get a new chassis as well, this one is scratched up and bent in a few places
