aqwut
Brushless Heavy Weight....
aqwut's Avatar
11.22.2007, 06:47 PM
A123s seems to be your cheapest route... $90 for a "VERY" good 5S2P pack...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
squeeforever
squeeforever's Avatar
11.22.2007, 07:00 PM
Aqwut, personally, I think the TrueRC packs are his best bet. He can get a VERY good 4S2P 8000mah pack for $140 as apposed to $90 for a 5S2P 4600mah (I think?) A123 pack thats ALOT bigger and heavier.
aqwut
aqwut's Avatar
11.22.2007, 08:17 PM
Very true dude, but gotta love the power output.... the 5S2p would pump close to 2300 Watts where as the 4S2P TrueRC would only pump about 1200 watts.... and you could charge the A123s 3-4 times faster with the appropriate charger... but the TrueRC pack would last longer for sure...
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
11.22.2007, 10:44 PM
Which aspect of 'lasting longer' are you talking about? Life time, or runtime?
As for cycle life, no one knows yet... that's how awesome they are, I am getting close to 300 cycles now and have only lost 75mah in a 1p configuration. Impressive.
MetalMan
MetalMan's Avatar
11.22.2007, 07:17 PM
5s2p A123 will be quite a bit larger than a True RC 4s2p 8000mah pack, but the weight difference will be about 70g, depending on how the 5s2p A123 pack is constructed.
zeropointbug
Z-Pinch racer
11.22.2007, 07:20 PM
What DOD (depth of discharge) do people here discharge their lipo's to? % wise.
highflier
Emaxx- FLM wannabe
11.22.2007, 07:27 PM
If you want maxx play time and it's not hard core competition the A123's are the way to go.
Make it a 6s2p pack... (12 cells)
For the 3 packs you listed that means you will have 6 cells left....
If you do your setup right you can charge the 6s2p pack in under 10-15 min. and the charging system is super cheap!!! Therefore you could run the remaining cells 6s1p. while the others charge. You will be a little heavier.. but with 6s2p there will be tons of power availible.
Now if you are going to the track to race, You'll want to shed the weight, and your run time requirements will be lower, So lipo's would be your best bet. You can pick up some charge between races and should have no issues with several races with a single pack.
I personally went the A123 route... but If I start going to the track I will get a set of lipo's to race with.
In Conclusion. Buy which ever matches your use plan.
Highflier
t-maxxracer32
t-maxxracer32's Avatar
11.22.2007, 07:33 PM
Highflier
probably the best description for me....
you hit the spot with eevrything you said.
i am going to be racing this truck so it looks like lipos it is.
i may buy 2 dewalt packs just to have for when i go bashing.
thanks guys
t-maxxracer32
11.22.2007, 08:26 PM
what would you say the lifespan of the a123 cells are?
and can you charge them at like 4c or something?
aqwut
aqwut's Avatar
11.22.2007, 09:10 PM
I think it's about 2000 cycles... and upto 4C charging... you really can't go wrong with either lipo or a123 M1.. batteries are beautiful...
david lamontagn
11.22.2007, 09:25 PM
I'am very interest to make a 6s2p A123 for my 1/8 buggy for bashing session (because for racinc i've already a Flightpower 5000, 4s).
OK explain me three thing please.
First: wich charger can charge A123 cells? because i've a ICE charger and not sure if i can charge this A123.
Second: Must i balance A123 pack when charging? If yes, how could i make a plug to balance it?
Third: where can i buy it?
Thank you
offroader
11.22.2007, 10:48 PM
Thank you
Here's a link which shows you how to make your own balance plug for your A123 packs but I read somewhere these don't have to be balance. Can't find the site that had that write up.
http://www.rcgroups.com/forums/showthread.php?t=599316
highflier
Emaxx- FLM wannabe
11.22.2007, 11:40 PM
Here is the real thread on how to charge the A123 cells fast
http://www.rcgroups.com/forums/showt...=8#post8593235
I charge them at 10+ amps. I start at 15+ and it tappers off as it goes.
You must use 3s or 6s packs though.
I balance them before and after the first few charges.. Then they are pretty good check them every now and them and you should be jsut fine. They take a good lickin and keep ticking.
Highflier
t-maxxracer32
11.22.2007, 11:44 PM
that thread seems hard to follow highfligher
i got bored after just skimming through the first couple posts.
nl12
nl12's Avatar
I would go with lipos Evo 30s are a great choice.
