LSP Conversion...
LSP Conversion... - 01.28.2008, 04:14 PM
coming soon! proposed setup is
Mega aCn 22/30/2F
Quark 80
Flightpower 5s 25c Lipo
Gearing: 15/50
here is the data:
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 50
Pinion Tooth Count: 15
Total Voltage: 21
Motor KV: 1770
Tire Diameter (inches): 5.7
Tire Ballooning (inches): 0
Motor Current Draw: 70
Motor coil Ω: 0
Spur/Pinion Ratio: 3.33 : 1
Total Ratio: 14.33333 : 1
Tire Circumference (inches): 17.91 inches (454.84mm)
Total Motor Speed: 37170 RPM
Vehicle Speed: 43.98 MPH (70.64km/h)
Effective Speed Rate: 2.09mph/V (3.36kmh/V)
Effective KV Value: 1770
Motor Torque: 0.28 ft-lbs
Final Torque: 3.99 ft-lbs
what do you guys think?
