BP-Revo
BMW M Power!
BP-Revo's Avatar
04.23.2007, 12:34 AM
Hey Mike - any possibility that an extended chassis will be up for sale? I very much want an extended chassis - another 25mm would be sweet! I just don't have the equipment to do it (to do anything really)... My tools are limited to a cordless drill, hand hacksaw, a reciprocating saw (that I like to stay away from) and a compressor rotory tool (that I try to stay away from as well).
I'l also quite interested into what becomes of the spur. For now, I'm just going to use a hardned pinion with the stock spur (I'll drop you an E-Mail on that once I get my motor - I'm the one thats been inquiring about the LMT 1530). I am planning to brace the heck out of the chassis to eliminate as much flex as possible to try to help with. Also, mechanical brakes should further help gear life.
04.23.2007, 12:40 AM
What?! No dremel? It's crazy what you can do with one of those. Just get a regular A/C one, not the battery one.
Do you have your CRT.5 yet? It's already pretty sturdy. It only flexes where the CD is. If you put a battery tray on there and maybe use a top plate from the CD to the front brace area, there is absolutely no flex whatsoever. And I tried to bend it quite hard (I put the middle of the chassis on the edge of my workbench and pushed).
BP-Revo
BMW M Power!
BP-Revo's Avatar
04.23.2007, 12:52 AM
I have gotten my CRT .5. Its sitting right next to me.
Brian, if you put your thumbs on the center diff area and have your fingers on the front and rear and push down, it flexes pretty significantly.
Given, this is with the chassis completely bare. There is nothing on it besides the front and rear braces and center diff assembly. I'm sure it will stiffen up when stuff gets mounted up.
Even so, I am planning to find some turnbuckles to mount to create a type of "upper deck." I will take some from the front top plate (probably the steering posts) to the front center diff mount, then take one or two from the rear center diff mount to the part of the wing stay thats on the inside of the rear shock tower (drill holes, of course).
I may get a dremel, but for now I'll stick with the compressor rotary tool (kind of like a dremel) - or maybe leech of MetalMan. LOL :p
MetalMan
MetalMan's Avatar
04.23.2007, 10:40 PM
Don't forget that I have a scroll saw, bench grinder (nice for smoothing edges) and a drill press, as well as some slight milling capabilities (with the drill press and end mill bits).
BP-Revo
BMW M Power!
BP-Revo's Avatar
04.23.2007, 11:01 PM
I knew you had a drill press, but not the other two. I'm really going to have to leach off you then :D
04.23.2007, 12:55 AM
Yeah, I did that when the chassis was bare and it did flex. With a battery tray, it strengthens it significantly.
Leeching off MetalMan sounds like the best (and cheapest) option to me. :)
jnev
jnev's Avatar
04.23.2007, 10:09 PM
Thanks for info Mike. Too bad about the useless spurs you made.
Can't wait for the final product.:027:
glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.23.2007, 11:54 PM
I talked to Mike today about the spur gear issue. I think I will have a solution in a couple days. Hang tight....
Mike has the motor mount covered... all we need is a sweet battery mount and the conversion will be super easy.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
gixxer
gixxer's Avatar
04.24.2007, 12:12 AM
sounds great, I should have my crt.5 in a few days. I didn't know mike was going to be making a battery mount too? That will make this even easier.
Now I just have to hope he finishes the losi 8t mount soon, or for that matter horizon to get them back in stock.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
glassdoctor
TEAM FUSION
04.24.2007, 12:21 AM
Well... I don't know that he is working on a battery mount. I talked to him today and that never came up... we were more concerned about the motor mount and gear. But a drop in battery tray would be killer to make a complete conversion.
A local guy wants me to come up with a battery mount... so I'm going to see what I can do. I will have his truck tomorrow to get started.
As for the losi mount.... my design never got done. The shop had issues with their cnc mill so the project is still delayed. I gave up on them... it's been months now. I may send my design to Mike so he can make a few for anyone waiting on it.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
04.24.2007, 12:46 AM
The Al battery tray I made is simple and effective. It could probably use a bit of tweaking, but is quite solid.
BP-Revo
BMW M Power!
BP-Revo's Avatar
04.26.2007, 01:15 AM
Well, my 1530/8 has officially been ordered through Mike. I sent him an email and he says he will let me know when it gets here. I'll be very suprised if it beats my 1950/6 here...since the 1950/6 has been on order forever. I'll probably send him an email bugging him on the 1950 sometime this weekend.
Now, I just need to find a CAD program to design myself an extended chassis :D
04.29.2007, 05:55 PM
Well, I've run about a dozen packs worth through the CRT.5 with the hardened steel pinion and it still seems to be fine. You can see the wear marks, but the overall shape of the teeth are the same.
However, it seems to have developed a wobble, probably because of the 1/8" to 5mm sleeve adaptor. The motor shaft spins perfectly fine by itself. Also, 16T is simply geared too high to continue to use it in this vehicle. So, I'll save it as a spare for my Hyper 8, which is also using a steel spur for testing purposes. I know Mike is working on a plastic spur solution, and so is someone else here, so I think I'll wait until then.
Serum
Serum's Avatar
04.29.2007, 05:59 PM
I kind of lost track on this topic; but is that an RC-monster pinion? it looks like it... are these the new hardened or the 'normal' pinions?
I personally don't see a sign of wear, (perhaps it's the photo) i only see the silver thru the black coating.. (which is pretty normal)
04.29.2007, 06:44 PM
Yes, it's one of Mike's pinions. I have a couple I am testing for him because I really think a solid, consistent mesh is the key to their longevity. Mike just asked me to post my results of this test here. I also have one on my Hyper 8, but haven't run that nearly as much since I'm saving it for race days.
And yeah, there is really no wear. The picture tells the story. I just have to stop using it because of the bore adaptor sleeve. Somehow it must have worn and the pinion wobbles slightly. I did have a time where the grub screw got loose so I suppose the shaft spinning at high speed on a stationary sleeve probably wore it down a little.
