Thread Tools Rating: Thread Rating: 57 votes, 4.93 average. Display Modes
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
01.03.2010, 10:20 AM
Originally Posted by sjcrss View Post
MC, I'm going to be picking up a set of these from hobbyking... http://www.hobbycity.com/hobbycity/s...dProduct=10285, and my question for you is, what kind of tap plug is on the end, is it like the hyperion, how and what do you use to balance you lipo's, I'm going to be using a lba10, that has hyperion plugs for the taps.... any suggestions.
Thanks
The description says JST-XH balance tabs. I have no idea what Hyperion plugs look like, to tell you the truth, I don't know what any plug looks like, I always have to ask someone I charge and balance my lipos with a CellPro 10S. What's a lba10? No suggestions
No brain, no headaches.
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
01.02.2010, 04:37 PM
  Send a message via MSN to shaunjohnson
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
01.03.2010, 10:59 AM
MC, I figured it out, and thanks for the reply, I learned that a hyperion/polyquest plugs are the same.... so by looking on the hobbyking site, I found a ext. that has the JST-XH tabs on one end and the hyperion/polyquest on the other end, so they will just plug right into my existing tap plugs on my balancer...... oh, here is a lba10, hooked up to my mrc 989 charger as well....
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
mistercrash
Guelph, Canada, eh!
01.03.2010, 11:56 AM
Hyperion and Polyquest are the same.... Ok MC try to remember this time I'll probably forget in five minutes. Whadawe talkin' 'bout?
- SmashBash -
01.03.2010, 12:55 PM
Wow! Nice build!
Have got ALOT of inspiration from you ;-)
- Thanks!
sjcrss
sjcrss's Avatar
01.03.2010, 12:16 PM
JST/XH is also known as Align
Hyperion is also known as Polyquest
this info is taken from here...
http://www.rctech.net/forum/r-c-item...-adapters.html
Bl E-REVO
Quark 125b
((2s2p)(4s)
phatmonk
RC carbon junkie
phatmonk's Avatar
01.03.2010, 08:05 PM
Tested my e revo today for some speed runs and my POS TRX am radio glitches like crazy.I have a MMM and Neu 1512 2x2s 5200 30c.The throttle cuts out under full throttle 80 ft away.Doesnt do it at short range.Also lost all control at about 120 ft.Do I need a servo spliter to run 2 servos off of 1 number 2 channel I will try my MX3 fm radio?
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
01.04.2010, 09:23 PM
For dual steering servos you mean? Yeah, just a regular Y-splitter will be fine- I used to do the same but then I discovered the joys of channel mixing with a 6 channel radio & 8 channel rx!
mistercrash
Guelph, Canada, eh!
01.07.2010, 07:09 PM
Brown Boy brought me a big box today and I received another smaller box from Japan also. I have two new Lifepo4 3S 4500 mah Turnigys, 8 Proline 40 series Mashers, 8 Axial 40 series chrome wheels and tomorrow I will pick up some Parma liquid mask at the LHS to start painting the two Proline Ford F650 bodies I have. Soon I will post some cool pics of the two ERBEs with the new bodies and wheels and I will post some graphs of the Turnigys and of course I will try them out in the snow.
rawfuls
roofles.
rawfuls's Avatar
01.07.2010, 07:34 PM
I wish my friends would call UPS brown boy......
And my dad be like you.
The LiFePo4 were new right?
...I thought they came from HongKong/China....
mistercrash
Guelph, Canada, eh!
01.07.2010, 10:59 PM
Man I suck at geography. Yes they came from China.
I put my new lifepo4 Turnigys on the CBA analyzer and this is what came out.
LiFePO4 1:
Discharge rate: 9.60 A
Starting voltage: 10.30 V
Ending voltage: 7.30 V
Total time: 26 minutes 49 seconds
Tested capacity: 4586 mah
LiFePO4 2:
Starting voltage: 10.40 V
Total time: 25 minutes 41 seconds
Tested capacity: 4105 mah
And the two graphs overlay ed
There's a small difference in the two as far as run time and capacity. I will analyze these packs again after they have a few cycles through them to see if they get better.
rawfuls
roofles.
rawfuls's Avatar
01.07.2010, 11:31 PM
*Facepalm*
I need to go back to school.. It's been too long, I guess I wasn't thinking, nevermind..
I'mmmmmmmm an idiot.
mistercrash
Guelph, Canada, eh!
01.08.2010, 11:27 AM
No you're not.
Some bashing this morning with the new 3S lifepo4 Turnigys. It's pretty much like running 5S lipo. But unlike lipo, the discharge curve of the lifepo is more progressive close to the end of the cycle. I mean that the packs don't dump suddenly like my lipos do. So after about 8 minutes (I didn't time it precisely) the power started to be less, like 4S for about a minute. Then it started to drop down even more, that's when I brought the truck back. The packs were slightly warm to the touch. Back on the charger, my CellPro showed 10% charge left. My lipos give me full power until the LVC kicks in and when I put them on the charger, they show 2 or 3% charge left in them.
Personally, I wouldn't use these lifepo for racing, I would rather have full power through the whole discharge that lipos give. But for bashing and having fun, the lifepo is awesome. No LVC, no puffing, recharge very quickly at very high rates and tough as nails.
One last thing, the water proofness of the ESC and servo proved to be excellent again and the double party balloon on the batteries kept them bone dry again.
mistercrash
Guelph, Canada, eh!
01.09.2010, 05:01 PM
I mounted those Mashers on the Axial wheels. I also put a little paint in the recesses of the wheels to give it a unique look. My F0rd F650 body will be red so I have a set of wheels with red accents and my son's F650 will be blue so a set with blue accents for him.
The tires and wheels/tires are big. At 420 grams each, they are going to be the biggest and heaviest wheels/tires I have evr used on my ERBE. But I think they look sweet. Real Monster Truck like.
My son's wheels are going to look even better because they have blue accents which will match the blue hue in the chrome from the Ofna adapters.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
01.09.2010, 05:46 PM
Real Purty Mr.C !
That boy of your is lucky to have an Ol' man to spoil him like you do !
