hemiblas
hemiblas's Avatar
11.03.2010, 09:36 PM
I must have read it wrong too them. Oh well. I hope you are enjoying the motors, like me. I'm still trying to figure out what to do with the 1717's I ordered.
Nard Cox
n00b
11.04.2010, 04:23 AM
Same here ;) But I have good news.
FLM is coming out with a new set of TVP's in about two weeks. This set will handle a 1717 + 6S LiPo between the TVP's :)
11.04.2010, 08:42 AM
Thats good news... Might mean I get my 1717 back from Jamie ;)
Bmr4life
11.04.2010, 09:38 AM
Nice. XL? XXL?
11.04.2010, 09:52 AM
Jamie was working on a Baja style version so XXL - fingers x's
toplakd
11.04.2010, 12:10 PM
My own Savage to Baja conversion with 560mm wheelbase
Place for batteries up to 157x74x55mm and 1717 motor sizes.
I'm using 7075 Aluminium for TVP's and motor-servo-battery plates.
Dejan
I removed my signature.
Bmr4life
11.04.2010, 12:59 PM
That's nice, but why not put the motor up front like some of the better conversions. I sold my TCS 5B because all it did was wheelie.
toplakd
11.04.2010, 01:04 PM
TCS uses stock savage rear dogbone, this one is moved forward and it uses xl size rear dogbone.
Here is the picture from test cuts, i made and weight distribution.
Bmr4life
11.04.2010, 01:07 PM
Oh ok, that's a lot better then. The weight difference between the 1717 and the titan 550 in your mock up shouldn't be a problem.
How'd you machine that?
toplakd
11.04.2010, 01:10 PM
With CNC mill.
I hope I will mill all parts till weekend and then show A complete Piece.
I will offer this product online, but I'm still waiting my custom dogbones from 303 stainless steel.
p.s.: The Titan is 775 :)
Dejan
thzero
11.04.2010, 02:56 PM
Note he also has the batteries inside the chassis. As I recall you didn't. This helps a lot with the weight distribution.
Bmr4life
11.04.2010, 04:09 PM
That's correct, but batteries up front wouldn't have helped nearly enough. I'll have to post a video of my 5B on asphalt. Simply moving the batteries up front wouldn't have solved my problems.
thzero
11.04.2010, 04:12 PM
You might be surprised. 5S/6S batteries are fairly heavy. However, yes I suppose that the traction would probably increase when running on asphalt. Much different than on grass, loose dirt, etc.
Bmr4life
11.04.2010, 04:15 PM
Yeah, I was only running 4s. 2 hard case 2s Turnigy lipos. With 5s/6s, I'd think it would be even more likely.
I was using the Terrapin tires, not sure if their large diameter had any effect on it.
toplakd
11.04.2010, 04:40 PM
Because of this, in my TVP's motor is moved 60mm forward compared to TCS.
Dejan
