Dafni
Dafni's Avatar
08.18.2005, 03:54 PM
Dabid, we already talked about this a while ago. Serum's right. If the air is blown on an object, you have more actual contact between air and surface. Thus the heat exchange is better.
If you suck air over it, the air will find the route with the least resistance. Which is not directly ON the surface. (in fact, theoretically, the air molecules that sit on the surface would not move at all)
-dafnerd
dabid
08.18.2005, 04:16 PM
Originally posted by Dafni
-dafnerd
So true, so true! ;)
Yeah, I vaguely remember you saying to have them blow down onto the controller heat sinks, but was unsure of what to do with the motor.......d'oh!
Dafni
Dafni's Avatar
08.18.2005, 04:20 PM
I see. I'll let it slide this time :p Good excuse, though :L:
Batfish
Batfish's Avatar
08.19.2005, 10:14 AM
Originally posted by Serum
Yeah.. Blow.. don't suck...
Best advice I've seen on these boards :D
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
Serum
Serum's Avatar
08.19.2005, 10:28 AM
It's all coming from Holland..
Land of the mills, clogs and good advices..
Dafni
Dafni's Avatar
08.19.2005, 11:00 AM
ROFL
I saw this one coming.
mothman
09.13.2005, 05:57 PM
Mark, do you know about Mikes heatsink/clamp? Will this fit your motor? If it is a regular 36mm diameter motor it will fit.
This wonderfull thingy allows you to mount a fan directly to it. 2mm screws just grab nicely inbetween the fins.
As for the ESC, a fan never hurts. I like them directly on the heatsink.
Here's some of my stuff. Most people here have already seen this pics. Anyway, just to give you an idea
On a Warrior
Top view of my truck
Another view
Dafni, is that 40mmx40mm fan that you put on you 9920? Looks cool. Im planning to put that on my 9920 (when mike has them in stock) 40mmx40mm is the smallest fan I can find at the moment.
mothman
On a Warrior
Another view
And 1 more question, I've found a powerful 40mm fan with 11.48cfm and 9200rpm. this is the highest cfm and RPM ive seen so far for a 40mm fan. But the problem is, it has 3 leads (pins). I know that most u use the fans that has only 2 leads, +ve and ground. can I still use this? How can i connect the fan with the rest of the electronics?
This is the fan that im talking about.
http://www.newegg.com/Product/Produc...01#DetailSpecs
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
09.13.2005, 08:54 PM
Not sure on the 3 pin connector, but it surely can be hooked up. I have some 12 volt, 2 pin fans if you need them.
To demonstrate the cooling effoects of suck vs. blow, think of a hot day. Which side of the fan do you stand on to cool down? The air blowing over you cools much better than standing behind the fan! Same principle.
mothman
09.13.2005, 08:57 PM
Thanks mike. Are you refering to the "cfm" when you said about blowing and sucking? I thought the cfm value shows how much air the fan can blow..
coolhandcountry
coolhandcountry's Avatar
09.13.2005, 09:06 PM
I think on the 3 pin connectors. They have a hot ground and sensor wire. Tell the computer what it is doing. I may be wrong on this.
Peace!
Country
Help support the
Rc-Monster
Buy here
RC-Monster Mike
Site Owner
09.13.2005, 09:17 PM
The suck vs. blow was referring to having the fan blow the air over the controller and motor vs. trying to have the fan blow air away from them(suck air away). The air blowing over them is much more effective.
cfm is the volume of air being moved. I was referring to where it it being moved to. :)
nitrostarter
nitrostarter's Avatar
09.13.2005, 10:14 PM
What do you guys use to power these fans?
N. Rustler conversion
RC-Monster Mike
Site Owner
09.13.2005, 10:31 PM
I run a 5 volt fan off the 3rd channel in the receiver. Sometime, I use a 12 volt fan powered by the main battery packs.
microdiladum
microdiladum's Avatar
09.13.2005, 10:36 PM
If blowing air on the heatsink cools better then pulling the hot air away for it by sucking why do all CPU heatsink fans pull away and not blow on? You think they would do it right?
I have always heard pulling heat away from the heatsink worked the best.
