skellyo
skellyo's Avatar
03.05.2008, 08:15 PM
I've been reading over this and hope you guys can answer a few questions for me.
Is the spur in this metric 48P like the MQ?
What Lipos fit the stock location? I noticed you mention the Dualsky lipos...are these the same 1700's that fit the MQ/Detta?
Is the stock servo a mini servo?
Sorry for the questions, but it's not like there's a ton of info on these from what I've seen. I may be interested in picking one up to bash with, but want to make sure I know how big my budget needs to be before I do so.
MetalMan
MetalMan's Avatar
03.05.2008, 09:00 PM
48p metric spur, mine now has a Robinson 22t 48p metric pinion on it.
The battery tray will fit packs that are maybe 1/8" wider than what the RC18T can fit, but about 1/2" shorter. Mine has an Impulse 3s 1330mah pack that fits perfectly aside from being about 3/8" shorter than the battery tray.
The servo is something like a mini, I think its about the size of a Hitec 85. I have found that a Hitec 225MG fits with the removal of some small ribs on the chassis, and cutting the tabs off from the servo.
skellyo
skellyo's Avatar
03.05.2008, 11:23 PM
Thanks for the info MM. Now I have to decide if I want another mini or not.
MetalMan
MetalMan's Avatar
03.05.2008, 11:31 PM
This truck is actually my first mini. A while back I was given a RC18T for free that only needed maybe $20 in parts to be operational, + electronics and battery. I gave that truck to somebody, and basically waited for the Rage to come out before getting a different mini. All in all, I'm glad I did so.
rschoi_75
Certified Spaceball
rschoi_75's Avatar
03.06.2008, 02:19 PM
Originally Posted by JerryF504 View Post
I wonder how the new Swinder Micro would work. It doesn't have an actual value under the continuous rating. It just says "More than you can handle!"
Yeah I read that and laughed. The new sidewinder micro is supposedly just a mamba 25 with a new sticker. I think they bumped it down to make room for their new Mamba Micro Pro, which is supposed to have a 35 amp constant rating. (I got this info from another forum).
Skellyo, the dimensions of the battery tray are 90mm L x 34mm W x 15mm H. Its a little longer than a standard MQ battery compartment since the XTM rage uses end caps on their stock shotgun style batteries. The height can always be changed by raising the battery posts. One thing to note, the xtm rage's battery compartment is molded for nimh's, so you may want to dremel off those ribs as well. The dualsky lipo I mentioned is the same lipo that will fit in a MQ. They currently have a 1300mah 25C lipo that fits perfectly.
rcm xt8
rcm xb8
rcm crt.5
skellyo
skellyo's Avatar
03.06.2008, 03:14 PM
Ok, so I broke down and bought 1...err, ok so I bought 2. I just couldn't help myself since I was able to get them both shipped for $190 total. I'll now be looking around at electronics for at least 1 of them for now. I may keep one stock to drive inside the house for now.
rschoi_75
Certified Spaceball
rschoi_75's Avatar
03.13.2008, 11:55 AM
let us know how it goes sean. good luck with them.
rcm xt8
rcm xb8
rcm crt.5
bumsnogger
03.01.2011, 11:03 AM
Hi,I just got one :) Mines a haiboxing marmot,but it's a clone except the shell.Does anyone know if the esc'll handle a 3s lipo.I've trawled everywhere else.I've got a hobbywing 5200kv and 35A esc,but don't want to wreck the tranny, like the ml$t2 :(
bumsnogger
03.02.2011, 08:35 PM
Hi.I took it out to a cool bashing spot today.It's a great truck.I've fitted mini mega beetle tyres,gonna try it out tommorrow :)
bumsnogger
03.16.2011, 09:41 AM
Hi guys.I broke the front left A arm,and the caster adjuster.Any hints to alu caster adjuster? Thanks in advance :)
bumsnogger
04.21.2011, 04:15 PM
Hi,I put a 3s lipo in it,Thats better :) .
