George16
Supermaxx
George16's Avatar
07.19.2008, 07:38 AM
How would I know if the fan is not working anymore? Or should I say, what if the fan fails to come on at 140*F and fries or thermals the MMM? Any built-in safety feature?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Jeremy1976
07.19.2008, 09:48 AM
Good question I was wondering that myself.
KINGSKID
KINGSKID's Avatar
07.19.2008, 10:45 AM
most of us won't be able to get the monster max to the point of thermalling. I run a 1.5d on 4s in a buggy and when the original fan failed the esc only got too 175 degrees. That was on a track in race type conditions in low 80's heat and a fifteen minute run. If your running a tamer motor or a slipper in a truck or truggy you may not need a fan at all.
auto2
07.19.2008, 12:16 PM
wow i asked for a thermostat on the fan.:-) this way the fan will llast so much longer.....
so when should i order another mmm and send in my working perfect mmm for an updated one?
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
07.19.2008, 07:29 PM
I don't know why cc make this case for the mmm
why they don't use case like this:
I really hate cc mmm design
(Upload)
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
07.19.2008, 07:37 PM
Can't see the pics g8-maxx
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
07.19.2008, 07:46 PM
DRIFT_BUGGY sorry now you can see :)
KINGSKID
KINGSKID's Avatar
07.19.2008, 08:01 PM
not sure of the venom, but cc would have to lower their quality standards to make the ecs fit the other cases!
George16
Supermaxx
George16's Avatar
07.19.2008, 08:40 PM
Like you said,
. What about the rest that can thermal the ESC? There is always the possibility and a newbie might take faiulre of the fan as an indication that the ESC is still cool even though it's not.
I don't have any problems (knock on wood) yet on my V1 on 1515 1Y on 6S. However, I will be exchanging it for the V2 once the backlog is over.
Revo with OS .18TZ
07.19.2008, 09:13 PM
BrianG did some mods to his fan and plans to not run a fan...curious as to how he makes out. I took my fan off of the esc and wired it to the rx and I am running an external bec so, we shall see what happens. I would be curious w/the v2 how temps would be w/out a fan on 4s then 5s
KINGSKID
KINGSKID's Avatar
07.19.2008, 09:44 PM
Like you said, . What about the rest that can thermal the ESC? There is always the possibility and a newbie might take faiulre of the fan as an indication that the ESC is still cool even though it's not.
George, Are you infact in that situation? If your running that setup in a truck or truggy and geared to race and not too the moon or in an above average climate, probably not. I've been one of the fortunate ones with a v1 monster. Hooked up my fan to my rx almost from day one. I've run overgeared just to see what could happen. this esc is pretty darn tough IMO
George16
Supermaxx
George16's Avatar
07.19.2008, 09:57 PM
I'm using s trobe slipper with 51T spur and 20T pinion. My diffs are 1/8 scale 8 spyders with 3.3:1 ratio.
Can't tell if I'm going to thermal it but the possibility is always there.
Revo with OS .18TZ
KINGSKID
KINGSKID's Avatar
07.19.2008, 10:00 PM
with the slipper,unless you really overgear, your safe.
DRIFT_BUGGY
07.19.2008, 10:08 PM
BrianG (i think it was) modded his body on his V1 MMM like this
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
07.19.2008, 10:16 PM
Yup, that's mine all right. Since then, I added the UBEC mod:
