10.25.2008, 01:21 AM
Originally Posted by mxracer View Post
i still think the fan plug is a weak idea.(they really need to improve on it ) when i get my replacements i will just run the fan from the aux port on the receiver. the problem with the switching fan idea is that if u bring your truck in after a few laps and the fan is not running , it could be either
1. not over 150deg
2. the fan/wiring is busted and not working..
so most would assume its not over 150deg and keep on driving but if the fan is not working due to damage , then you will just keep driving until smoke comes out . (exactly what happened to one of my esc's) ..and those fans are not very tough at all.
If you are going thru all the trouble to attach the wire to the rec, why not just add the shrink like I did and re-route the wire. The fan plug on the pcb has plenty of clearance with the bottom case now, unless the pcb breaks in half the fan plug will not touch. The fan wire is the only problem I see now. All of mine will be modded like this, and I expect them to work fine.
tc3_racer_001
tc3_racer_001's Avatar
10.25.2008, 02:43 AM
also, just switch the esc off and on. if the fans spins again on startup then its fine, if not then time to investigate? or just use a pocket temp guage!!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
BlackedOutREVO
10.25.2008, 01:12 PM
So this is still an issue. Ohh well, honestly as long as the speedo works, I cant complain. For the price, and everything about the MMM. Its worth it (to me)
Nice to see they kept the bullet plugs!
