yeah heres the best one http://www.rc-monster.com/proddetail...MBO2200&cat=20 select motor only and mike will ship you one for 150. much better for a emaxx than a medusa as the endbells are closed. plus castle always makes good on the warranty
I see that you have the smaller shaft (1/8") HV, now you were running on 4S right??? Isnt the 4.5 5000kv???? If so, wouldnt that be like 74000rpm???? or was the old HV4.5 KV different???
yeah its a old 1/8 shaft motor , and novak says on their site its 5000 kv
yeah 4s
if geared according to novaks specs , it will run ok , i had no temp issues at all when geared with a 12t on the 4.5 motor , it was about 120f , and a 13 iirc jumped to 145f so i ran a 12t
also remember that a monster trucks trans has a gear reduction , not a great set-up but if you have the motor it will work fine
