RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.22.2006, 11:53 AM
I should see your controller anytime, Travis. Nbcz...my money says you knocked something loose.
MetalMan
MetalMan's Avatar
01.23.2006, 11:18 AM
Really?!? I wasn't even expecting it very soon. Any idea on repair costs?
nbcaznmaster
RC-Monster Cult Member
nbcaznmaster's Avatar
01.24.2006, 02:14 PM
when stuff is knocked loose, is it ez to fix?
MetalMan
MetalMan's Avatar
01.24.2006, 09:07 PM
Sometimes. In my case, a chip was partially damaged, but replacing it didn't seem to fix the problem. That's why Mike sent it in to BK.
nbcaznmaster
01.26.2006, 07:05 PM
opened up the esc, nothign is loose. Looks perfect. Most likely is interneal. So im screwed. Any1 wanan buy a damaged esc?
MetalMan
MetalMan's Avatar
01.27.2006, 12:18 AM
Send it to Mike to get it fixed! Or, just have Mike take a look at it.
Serum
Serum's Avatar
01.27.2006, 03:28 AM
yeah, don't loose faith too quick Nbacz!
nbcaznmaster
01.27.2006, 07:38 AM
ima send out to mike this friday or sat.
nbcaznmaster
01.30.2006, 07:33 PM
Hey mike! if u see this, i sent out esc monday! hsould be there wed or thursday!
nbcaznmaster
02.14.2006, 05:26 PM
Mike says the esc is perfectly fine.... lol, theres a waste of time. I asked mike if he could put it on a car and test it out ot be 100% sure.
coolhandcountry
coolhandcountry's Avatar
02.14.2006, 06:27 PM
Did you send the motor with it? That away he could have tested both of them out.
Peace!
Country
Help support the
Rc-Monster
Buy here
nbcaznmaster
02.14.2006, 07:01 PM
ya, i sent both in
02.14.2006, 11:13 PM
Well, that's good news at least! So, maybe your problem is in your batteries; a partially broken/loose solder connection on the batteries maybe. Would make sense since a bad/loose solder joint can't supply the current the ESC will try to pull.
Man, I really hope I don't blow my controller somehow when it comes in! I think I'll definitely make some type of ESC box to protect it and support the wires (while maintaining adequate cooling of course). Might be worth the effort!
nbcaznmaster
02.23.2006, 07:29 AM
NOOOO!! when mike tested it out on his g2r, it coggs baaddlY!! ITS GARBAGE!! $200 DOWN THE DRAIN!! WHY!?!?!?!!
MetalMan
MetalMan's Avatar
02.23.2006, 10:08 AM
Get used to it (lol!). He can send it in to BK, and there's no way that they will charge you full price for it. So, it might only end up being $120 down the drain :).
