09.11.2007, 09:11 AM
Originally Posted by BrianG
Seriously, a slipper would be nice for those times where I'm a little overzealous and land from a jump on throttle. Other than that, I don't miss not having a functional slipper.
I'm with you...I don't want a slipper, all I want is something to protect the drivetrain from too much shock. Set it ultra-tight so it only slips at extreme pressure and that's all I'd need.
DM
09.11.2007, 11:32 PM
it can handle drivetrain protection easily. that's its original intent. but some folks out there will run it in slip no doubt, be it accident or intentional. so it was almost prudent to try and design in the ability to handle power trimming slip. But that is what makes it so tricky.
I'm telling you though, one time while searching for the over-slip failure point in a destructive test, i dialed in such a perfect slip the truggy became so controllable it was surreal. Haven't taken the time to find it again lately but it's there to be found.
09.12.2007, 10:12 AM
Can you post a picture of the slipper/diff your have or at least the link to it.
Thanks!
09.12.2007, 10:58 AM
You can see a little of it in the picture below:
The dark blue is the spur, the light blue is the tension adjuster. IIRC, the diff casing is threaded so the adjuster screws in/out tightening/loosening the slipper.
09.12.2007, 11:02 AM
Thanks Brian,
I was sketching out some ideas for a CRT slipper when I realized several other have been working on this as well.
Duh!
09.12.2007, 04:13 PM
here is a little bigger of a pic of the slippery differy
Hows that "Hope and Change" working out for Ya???
09.12.2007, 04:15 PM
THANK YOU!
That's a great looking set-up! Is there a "differy" hidden there too or just the "slippery"? LOL!
09.12.2007, 08:41 PM
Originally Posted by Procharged5.0
THANK YOU!
a differy is in the middle, same as your differy
09.12.2007, 04:19 PM
That's a nice wide spur there too! I see there is a grub screw, presumably to prevent the tensioner adjustment from self-adjusting?
09.12.2007, 04:23 PM
Correct - and the oily residue is from wd-40 on the chassis - not the slippery differy leakerly... LOL
09.12.2007, 06:04 PM
I just figured the oiliness was from the exhaust of other stinky nitro vehicles that were on the track previously.
Is adding "er" to BL terms going to be the next "thing"?
09.12.2007, 06:38 PM
Brian,
It's from the exhaust of all the nitros you pass each and every lap!
09.12.2007, 09:34 PM
Brian,
lol, passing the nitros isn't the problem; it's keeping my vehicles on the tires that is. I tend to overthrottle it (just because I can) and usually wayyy overshoot jumps and/or go too fast around corners.
