Go Back   RC-Monster Forums > Support Forums > Team Tekin
TexasSP
Something, anything, nothing
TexasSP's Avatar
02.22.2009, 12:20 AM
Continuous Current: 210 Amps*
*Per FET manufacturer spec sheet
I would like to know what the real number is. This sure seems kind of "novak" of them.
I am with kulangflow, what exactly is in it for the price difference?
www.cubicle101.com
e-mike
e-mike's Avatar
02.22.2009, 12:17 PM
+1 on it....
D8t on juice!!
teamtekin
teamtekin's Avatar
02.24.2009, 07:57 PM
It is a real number from the spec sheets but I agree it is a bogus claim. It is how many controllers are rated and does give a fair best case comparison. However it is very dependent on cooling and the circuit board design and real constant current is typically a lot less.
We tested to 130A continuous and could not shut down the unit due to thermal or failure. That would dump your 5000mah battery in less than 3 min. It has shown to be pretty burley and even impressed us. Time will tell, but I think a lot of people are going to be smiling like we are. The Dual Mode drive is sweet and consistent.
TexasSP
TexasSP's Avatar
02.24.2009, 11:21 PM
Thanks for that info. I am not trying to be hard on you it's just a lot of manufacturers have left the RC community jaded with bogus, inflated, and/or untested claims. This has been running rampant in the lipo world as well.
I have nothing against tekin, and am happy to see more products coming to market. I just want to know "why" I should buy the controller.
I am a shopper, and like to here "what it has" etcetera before deciding. I never want to heat why the competition is bad, but really what you have to offer. I can comparison shop myself based on good information given.
www.cubicle101.com
teamtekin
teamtekin's Avatar
02.25.2009, 07:02 PM
Valid question I am looking forward to answering shortly. That takes a little thought to really explain what makes us different and mention some specific features and advantages.
e-mike
e-mike's Avatar
02.25.2009, 07:07 PM
i will wait...o yesi will wait....so 130amps....its very good...there 2 month before the snow melt here
D8t on juice!!
teamtekin
teamtekin's Avatar
02.26.2009, 07:47 PM
Thanks for the opportunity to lay it out. In short we make great products with personal commitment, offer them at a fair price and support them.
Currently we truly do stand alone with the only high power system with 40mm multipole motors that are sensored and run sensorless for perfect response in any situation. In addition we really have done a good job with features, size and performance. You can adjust almost everything right on the unit with few quick button pushes and the hotwire lets you really dial it in.
Like all of our products no compromises have been made right down to the dual contact, self cleaning power switch and servo plug that is best we could find for fit and signal quality. We use gold plated solder posts for tight installs and low losses. We have a small PC for a micro that gives us the ability to update and improve the unit ongoing. We buy leading edge components and use super heavy copper power boards. The fan is quick and easy to replace since we know they will break at times and the housing is made of tough Polycarbonate instead of the typical ABS. The Rx8 is the smallest footprint, handles as much power as the batteries can deliver with control and feel.
The Rx8 has a ton of user feedback with the 7 leds to show error codes and help diagnose issues. We show you if there is no radio signal, or we do not like the signal, or it is not changing like when a spectrum receiver will hand us the default neutral when it is not communicating with the transmitter. We have a real time temp monitor so you can look down and quickly know your internal temps and drive off again. We even have a sensor checker that allows you to see if all the sensors are working correctly. The top 3 leds light up with the sensors and you can turn the motors slowly with your fingers and watch them tick away.
It is also backed by Tekin, which means support by people that are as passionate about the hobby as you are. In the near future we are confident it will speak for itself in terms of performance, reliability and overall satisfaction.
Buy Idaho!
Semi Pro
Semi Pro's Avatar
02.26.2009, 07:59 PM
Buy Idaho!
what will the warrenty be on the rx8 system?
will teken still warrenty the system if we are useing it with nue 1509 motors?
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
02.28.2009, 01:27 PM
speaking of spektrum, has there been any issues with compatability or calibration? I'm running the DX2, and sometimes other escs have arming issues without a programming card. could you speak to that at all?
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
Semi Pro
Semi Pro's Avatar
02.23.2009, 03:27 AM
$200 for the esc sounds good to me, i will be ordering one to test against my mmm
gixxer
gixxer's Avatar
02.23.2009, 10:50 AM
I am fine with the price. Its $50 more for the combo then the Monster. For that its smaller, sensored and the rs series are easy to adjust even with out the hotwire.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
teamtekin
teamtekin's Avatar
02.24.2009, 07:52 PM
Might as well get it out there. Minor disaster has struck and we have had a small delay. We hate Murphy….
Last week the housing mold was damaged when setting up for the volume production run. We had hoped the repair would not be too bad and spent the last week trying to get it done, but it has turned out to be a total loss and part of the mold has to be re-cut completely. For those that understand injection molding this is not a process that can just be hurried with extra effort. It can take literally weeks to cut a detailed mold. It is a tedious process, but it is a local vendor and they will press hard for us. It will be at least 2 to 3 weeks before we can get the tool back on the machine and make some parts. On the bright side that is closer to when the motors will be available so we will have systems not long afterwards.
No one is more annoyed than I am. At least it is not a technical problem and is just an oops. We press on and still will be within a reasonable amount of time of the original estimate for release.
Tekin Prez
Electric Dave
02.24.2009, 08:13 PM
We have been conditioned to accept delays so no big deal on the mold.
Sounds like they will be out in the wild just as the 2009 off road season starts (in the northeast) which is fine by me.
teamtekin
teamtekin's Avatar
02.26.2009, 08:13 PM
The 1509 is a smaller motor than our 4030 or 4038 and I see no problem.
Tekin warranty is 120days on all products. We are starting to get stricter on receipts and causes because people do try to take advantage of our good nature. Growing pains that come with broad success. Fortunately our warranty issues are impressively low on all products. This product is going to get beat up a little harder than most.
TexasSP
TexasSP's Avatar
02.26.2009, 09:56 PM
Have you used beta testers with a variety of real world applications? I mean everything from hardcore racers to hardcore bashers?
I love my MMM, but CC's biggest mistake was lack of beta testing with a variety of setups and uses. With the issues worked out it is a keeper for sure. I have interest in the tekin for another vehicle though.
What are the restrictions and/or suggestions for setups using non tekin motors?
I wanted to clarify this last question. Is the controller setup to run 4, 6, or higher pole motors smoothly? What are the limits in these areas? Has testing been done with any outrunners?
www.cubicle101.com
