Patrick
Patrick's Avatar
12.23.2007, 11:37 PM
Originally Posted by Serum View Post
I hope you mean 6S A123 or NIMH cells? the quark isn't capable of 6S. I need to come across the first who uses 6S lipo packs in his truck with the Quark without killing it.
I use mine on 6s every once in a while and it works perfect so far. I usually keep the gearing the same as when it's on 5s, but it doesn't get much warmer. No caps, no internal mod, just the rcm heatsink with a 40mm novak fan.
nl12
nl12's Avatar
12.23.2007, 11:39 PM
I cant wait till I can buy one of those trannys on ebay
12.24.2007, 08:31 AM
Cheers Sike! I will go see how that compare to my old tranny and its mounting pattern/measurements....
**5 minutes later**
.... oh crap, not even close! The new tranny is 41mm by 52mm you said, but the old tranny bolt pattern in 54mm wide by 34mm long (outter most mounting bolts). Thankfully since the new tranny is narrower, it will still fit where the old one goes, but being longer as it were, will require a rather clever mounting adaptor- time to get designing me thinks, then I can sell it to the noobs on the traxxas forum, ha ha ha!....
sikeston34m
sikeston34m's Avatar
12.24.2007, 01:44 PM
What I wanna know is, How is the 2 speed kit going to work on this Transmission?
The Radio that came with this does NOT have the additional channel for shifting.
However, there is a small knock out window in the chassis that appears to be where the shifting servo goes.
There is also a blockout plate on the transmission that appears to be for a sensor like the Revo has.
Could this setup automatically shift to 2nd gear based on RPM?
THAT would be cool!
how about this setup in a revo with the new e-maxx tranny?
how about this setup in a revo with the new e-maxx tranny? - 12.24.2007, 02:26 PM
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.83
Other Ratio: 1
Spur Tooth Count: 38
Pinion Tooth Count: 14
Total Voltage: 22.2
Motor KV: 1700
Tire Diameter (inches): 4.5
Tire Ballooning (inches): .5
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 2.71 : 1
Total Ratio: 14.13725 : 1
Tire Circumference (inches): 17.28 inches (438.88mm)
Total Motor Speed: 37740 RPM
Vehicle Speed: 43.68 MPH (70.17km/h)
Effective Speed Rate: 1.97mph/V (3.16kmh/V)
Effective KV Value: 1700
Final Torque: Amperage not specified...
the tires would be panther komodo's
12.24.2007, 04:14 PM
You may have clearance issues with the motor and tranny with the small spur and pinion.
12.24.2007, 04:16 PM
THAT would be cool!
And auto shiting sensor based servo actuated shifter would be cool, would allow forward and reverse from the electric motor without needing a one way bearing. The complete 2 speed kit is listed for the emaxx at $55 IIRC. Plus it has different ratio gear options like the revo and tmaxx.
sikeston34m
12.24.2007, 05:02 PM
And auto shiting sensor bases servo actuated shifter would be cool, would allow forward and reverse from the electric motor without needing a one way bearing. The complete 2 speed kit is listed for the emaxx at $55 IIRC. Plus it has different ratio gear options like the revo and tmaxx.
Is there a website that has pictures and details about that?
Tower hasn't posted any details yet
12.24.2007, 05:12 PM
Look at the parts list, middle of 3rd page under transmission #3998"
http://www.traxxas.com/products/elec...905-071218.pdf
also:
http://www3.towerhobbies.com/cgi-bin...?&I=LXTKP9&P=7
sikeston34m
12.24.2007, 05:29 PM
OK, correct me if I'm wrong here.
It looks like to me this will be the gearing options.
Existing gears inside the transmission are 33/18 or 1.83:1
The close ratio set is 21/18 or 1.16:1 Which is a much higher 2nd gear.
The wide ratio set is 26/13 or 2:1 Which is a slightly lower 1st gear.
sikeston34m
12.24.2007, 05:48 PM
Remember this setup that you said looked a little slow?
Other Ratio: 1
Spur Tooth Count: 40
Pinion Tooth Count: 25
Total Voltage: 14.8
Motor KV: 920
Tire Diameter (inches): 5.75
Tire Ballooning (inches): 0
Motor coil Ω: 0
Spur/Pinion Ratio: 1.6 : 1
Total Ratio: 8.33354 : 1
Tire Circumference (inches): 18.06 inches (458.83mm)
Total Motor Speed: 13616 RPM
Vehicle Speed: 27.95 MPH (44.9km/h)
Effective Speed Rate: 1.89mph/V (3.03kmh/V)
Effective KV Value: 920
That's because you were just running it in first gear!
Look at it go in 2nd!
Transmission Ratio: 1.16
Other Ratio: 1
Total Voltage: 14.8
Motor KV: 920
Motor coil Ω: 0
Total Ratio: 5.28246 : 1
Vehicle Speed: 44.09 MPH (70.83km/h)
Effective Speed Rate: 2.98mph/V (4.79kmh/V)
Now let's use the 36 tooth spur and put it on 6S.
Other Ratio: 1
Spur Tooth Count: 36
Total Voltage: 22.2
Motor KV: 920
Motor coil Ω: 0
Spur/Pinion Ratio: 1.44 : 1
Total Ratio: 4.75422 : 1
Total Motor Speed: 20424 RPM
Vehicle Speed: 73.49 MPH (118.05km/h)
Effective Speed Rate: 3.31mph/V (5.32kmh/V)
I'm sure the motor would give up the smoke before 73 mph. I don't think it can put out enough watts of total power without blowing the winding. Motor temps will determine it's limits though.
I'll be sure to put the motor cooling fan on this to help raise the bar. I think the 920kv motor will be best. It will make more torque than the 8 turn wind. The 920kv motor is also rated for more voltage from the factory.
Before I settle on choices, I'll do some more checking. I'll also get all 3 spur gears to allow for some fine tuning.
12.24.2007, 06:23 PM
Yes, I ran all of those numbers, but figured that you would use the existing tranny gears for your setup. If the 2 speed is an auto shifter via the servo and some sort of rpm sensor, then your 920 kv motor will most likely get it over 60 mph without much of a heat issue. It would be killer cause 1st gear would let the outrunner startup easier and not put as much load for light bashing, and then when you really get on it 2nd gear will allow for some killer top speed. Or gear it for 45mph in 2nd and have some killer torque in 1st gear!
I have noticed this with my teckno converted revo. I still have the 2 speed tranny and it will run fine with a small aveox motor (l can size). Plus you can go low speed with it, just don't go fast enough to engage 2nd gear. It will almost pull a wheely when shifting at full throttle!
Is the 920kv good for 6s? That is 20k rpm which should be fine.
12.24.2007, 06:42 PM
Also for the different gears to fit correctly in the tranny a different size idler will have to be used. The input and output shafts are a set distance away from each other and the 18 / 21 setup will have to have a larger than 20t idler to fit and mesh correctly. Wonder how they will do this?
Both the 21/18 and the 26/13 would fit in the tranny as 1st and 2nd gear respectively and could use the same size idler for both, as the radius of both sets of gears added together is the same.
EG. 21t=23mm/2=11.5
18t=20mm/2=10
___________+___
21.5mm
26t=28mm/2=14
13t=15mm/2=7.5
___________+___
21.5mm
So I guess that when installing the 2 speed the original single speed gears will be discarded. Sounds cool, can't wait.
sikeston34m
12.24.2007, 10:58 PM
Let me take a few minutes and show you my favorite setup with the Direct Drive to Transmission outrunner setup. The Motor is a Century 600. It's stator is a 3530 and at 5 turns is rated for 715kv.
In first gear, there is NO cogging at all. It will blast off the line at WOT with the front wheels in the air every time. Without a wheelie bar, it will flip onto it's lid.
Transmission Ratio: 2.769230769230769
Other Ratio: 1
Spur Tooth Count: 1
Total Voltage: 14.8
Motor KV: 715
Motor coil Ω: 0
Spur/Pinion Ratio: 1 : 1
Total Ratio: 7.88166 : 1
Total Motor Speed: 10582 RPM
Vehicle Speed: 22.97 MPH (36.89km/h)
Effective Speed Rate: 1.55mph/V (2.49kmh/V)
Effective KV Value: 715
Here's 2nd gear on 4S.
Transmission Ratio: 1.7222222222222223
Other Ratio: 1
Spur Tooth Count: 1
Total Voltage: 14.8
Motor KV: 715
Motor coil Ω: 0
Total Ratio: 4.90171 : 1
Vehicle Speed: 36.93 MPH (59.32km/h)
Effective Speed Rate: 2.5mph/V (4.01kmh/V)
Starting in 2nd gear, it would cog about 10% of the time if I grabbed WOT off the line. If WOT was grabbed at anything above 5mph, it would raise the front end and really haul! VERY good acceleration with this setup.
On 6S, this setup would blow the transmission! It would either rip the teeth off the output gear or the output shaft would strip the drive dog hole.
Other Ratio: 1
Spur Tooth Count: 1
Total Voltage: 22.2
Motor KV: 715
Motor coil Ω: 0
Total Motor Speed: 15873 RPM
Vehicle Speed: 55.39 MPH (88.98km/h)
I love how this is going to come together. Finally I can put together an outrunner setup with a slipper and the kind of gearing it needs to show what it can do.
I'm going to go with the two speed transmission kit. Motor choice will be the AXI 2826/10.
Look at the 1st gear total reduction ratio. It's less than the century setup. It won't cog at all being so much less.
Other Ratio: 1
Total Voltage: 14.8
Motor KV: 920
Motor coil Ω: 0
Total Ratio: 9.10769 : 1
Vehicle Speed: 25.57 MPH (41.08km/h)
Effective Speed Rate: 1.73mph/V (2.78kmh/V)
Now check out 2nd gear. A Respectable 44 mph.
Other Ratio: 1
Total Voltage: 14.8
Motor KV: 920
Motor coil Ω: 0
I'm going to order a 25 tooth mod 1 pinion AND a 22 tooth pinion from Mike. Combine this with all 3 Revo Spur gears, the 36, 38, and 40 tooth, and I have should have all the adjustibility I need to make a SWEET 4S setup.
If I feel the need for more speed, I'll go 5S or 6S if motor temps and startups remain good.
A Quark 125amp Monster Pro with a Novak Cap and a heat sink. And all this with a TOUGH slipper like so much discussion has been about concerning the outrunner setups.
I'm gonna love this!
12.25.2007, 11:39 AM
Hey Sike, your 2826/10 setup looks good. I would say to do with a higher voltage setup, but the stock chassis setup really lends itself to 4s, either 2 larger 2s packs in series, or 2 smaller 4s packs in parallel. I have some ployquest 12c 3600 cells (8 of them) and as long as they fit I will make up a pair of 3600 4s packs. It will be nice to have a sturdy tranny and slipper! Lets see how this proposed setup works and I may have to give it a try!
Any idea what you think average and max current draw with this motor would be? Mainly cause I have a mgm 90amp 4 cell esc that needs a home, and the mgm escs will run an outrunner IIRC.
