MetalMan
MetalMan's Avatar
11.05.2008, 06:20 PM
Which track is that? Looked a bit big for the .5 . Nice work!
GO-RIDE.com
11.05.2008, 07:03 PM
Riceman,
The stock pistons in the 1/8 CR front shocks are 1.4mm holes. Try the 1.5mm hole pistons and 30 or 35 wt oil. The rear will work much better and cut down on the bouncing.
What 3S lipo are you using? Do you know the weight of it? I'm going to the same MM, Medusa 50mm 3300, and Rhino 3S 4000 lipo for my RCM chassis CRT.5.
E-8ight - Tekin RX8 2000kv/4S
riceman
RC-Monster Gold
riceman's Avatar
11.14.2008, 01:22 AM
Metalman - The track is ARC in Temecula. Not too far from you. Maybe we'll see you out there sometime?
Go-Ride - Not sure if I have any punch control in there or not. I'll have to hook up the Castle link and find out for sure. Diffs are 3K/3K/1K. What do you have in yours? Maybe up the center diff a bit.
GO-RIDE.com
11.14.2008, 10:52 AM
Originally Posted by riceman View Post
Metalman - The track is ARC Go-Ride - Not sure if I have any punch control in there or not. I'll have to hook up the Castle link and find out for sure. Diffs are 3K/3K/1K. What do you have in yours? Maybe up the center diff a bit.
I've been running 2/3/1 which worked great on our normally loose back yard track with my Novak GTB/6.5 and 2S. However, with the Medusa 3300 on 3S it was not working so well. I can still drive the car fast at partial throttle, but over 1/2 and it balloons & lifts the front wheels. I've got it set up at 2/5/1 for my next run which should be Sunday. I'm also going to tape the inside of the tires, but that takes time unglueing and reglueing the tires.
bustitup
11.14.2008, 12:01 PM
what an awesome track..tamacula? where is that?
MetalMan
MetalMan's Avatar
11.14.2008, 02:33 PM
Temecula is pretty much out in the middle of no where
http://www.mapquest.com/maps?city=Temecula&state=CA
