maxxdude1234
maxxdude1234's Avatar
03.02.2006, 03:30 PM
lol neweuser. pcnutz, the resistance of a given L motor is the same resistance of the same XL motor. Check out this table (at the bottom) http://64.233.179.104/translate_c?hl...l%3Den%26lr%3D
See how the resistance of the L motors and XL motors are pretty much identical. However, XL motors are more efficient because they run cooler (better heat distribution) and they have a higher kt rating and don't need to pull as much current.
pcnutz
pcnutz's Avatar
03.02.2006, 03:42 PM
dunno about that chart, why would a bigger motor with more wire have less resitance
neweuser
neweuser's Avatar
03.02.2006, 03:44 PM
again i have to say thanks to macfjej, he referred me here and it has been most helpful! and to you maxxdude...i anticipate my project being awhile, but i think with all the info and specs from you guys, it'll be pretty decent!
maxxdude1234
03.02.2006, 04:03 PM
pcnutz, although the wires are longer they are also thicker. With higher turn motors, there are more turns (longer wire) and the wire also becomes thiner, hence resistance increases and less current draw.
pcnutz
pcnutz's Avatar
03.02.2006, 08:20 PM
tonight build pix
HTTP://users.adelphia.net/~tjjohnson2/hybrid3.jpg
HTTP://users.adelphia.net/~tjjohnson2/hybrid4.jpg
pcnutz
pcnutz's Avatar
03.03.2006, 08:05 AM
my next step is to mount motor and batteries for balance, whats the best way todo this
Sylvester
Sylvester's Avatar
03.03.2006, 08:07 AM
On those chassis, it looks like gmaxx straps would work perfectly, how many cells are you running? looks good so far.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
pcnutz
pcnutz's Avatar
03.03.2006, 08:09 AM
I am using 7 cells each side with twinforce batt cages slung under, need to figur out how to balance the truck to mount them
pcnutz
pcnutz's Avatar
03.03.2006, 08:29 PM
nother set of tonighs build pix
HTTP://users.adelphia.net/~tjjohnson2/hybrid5.jpg
HTTP://users.adelphia.net/~tjjohnson2/hybrid6.jpg
pcnutz
pcnutz's Avatar
03.04.2006, 04:27 PM
still getting it done, just to let you know what I have for it
torpedo chassi
flm hybrid bulks with kyosho buggy gears, kania tcd diff in front
UE shock towers
proline suspention with power stroke shocks
RPM knuckels with 15mm bearings
titanium front skid
titanium cvds front and rear
rc alloy rear center and twin front center cvd
traxxas alumium hexes
BK wanderer 8xl
shulze 18.97 esc
twwinforce chain drive trans worked perfect fit
14 gp3300
coolhandcountry
coolhandcountry's Avatar
03.04.2006, 04:42 PM
When the video coming out? Sounds like a cool combo and looks cool to.
Peace!
Country
Help support the
Rc-Monster
Buy here
pcnutz
pcnutz's Avatar
03.16.2006, 09:35 AM
HTTP://users.adelphia.net/~tjjohnson2/hybrid7.jpg
HTTP://users.adelphia.net/~tjjohnson2/hybrid8.jpg
well I finaly got it together. but I got alot more work togo. the motor is kinda slow on 12 cells and 18/50 on the twin trans going to have to rework my 14 with longer power wires to reach from under the chassi and go up 2 teeth on the pinion, but so far I am happy with the setup
Cadtech
03.16.2006, 01:21 PM
Looks like an interesting project!
Unrelated to the build, but you really need to
a) get a better camera, and
b) resize your pics! Even on T1 at work, it's taking forever to view your pics.
boss 302
03.16.2006, 03:27 PM
really? the pictures came up on my computer in less than a second
maxxdude1234
03.16.2006, 03:29 PM
Dito, on 2mbps, takes about 4 secs to load
