Rivermaxx
08.31.2009, 03:37 PM
How big of gears do you guys want?
Go to sdp.si.com and go to "Buy Online". Click on the Metric Unit button. Then go down to the option for Gears. Then click on Spur Gears, next click on the suboption called "Metal". Then you should be able to adjust the search functions for 5mm bore and Mod1 specs and voila! Metal gears in Carbon steel, 2024 Aluminum alloy, 303 Stainless Steel. Teeth numbers available: 14,15,16,18,20,22,24,30,36,42,48,54,60,72,84,96.
Id be interested in the 30 and possibly the 36 but I am not sure what the "pressure angle degrees" means. It says only 20* is the only one availiable . Now looking at my spur it says 14.5* so I am not sure it will work with my spur gears.Anybody know if they are compatible? It also looks like they sell the same plastic gears up to 28 tooth that kershaw sells. sdpi sells them for less money also but I dont know what the shipping would be.
Rivermaxx
08.31.2009, 03:48 PM
Hey dwight how much for the 1.5d? It might work good in my setup. did you do anything like tape the inside of the tires or are the stock.
emaxxnitro
emaxxnitro's Avatar
08.31.2009, 04:54 PM
on the foams. if they spin will they chip? i mean my street is pretty rough. should i go for a smooth street?
808E
nitrostarter
nitrostarter's Avatar
08.31.2009, 05:43 PM
http://shopswarf.orconhosting.net.nz/spur.html
Thats a description of the Pressure angle. It seems as though it really wont matter, but the 20* is becoming most prevalent.
N. Rustler conversion
Rivermaxx
08.31.2009, 06:06 PM
With those foam tires you need to control the tire spin or you'll wear them out quick. Don't stab the throttle ease into it and try not to spin.
It specifically says the teeth that are meshing must have the same pressure angle, So those gears wont work with my set up or spur. The plastic ones will but I still don't think they are strong enough.
emaxxnitro
emaxxnitro's Avatar
08.31.2009, 07:02 PM
should i clean and lube my bearings?
808E
nitrostarter
08.31.2009, 07:09 PM
Definitely! Freshen up and clean everything. I would replace all bearings if capable. The least amount of rolling resistance as possible is the best!
emaxxnitro
emaxxnitro's Avatar
08.31.2009, 07:25 PM
THATS OUTA THE BUDGET. for now at least. a set of acers would be great . plus i like the poster they send you
808E
08.31.2009, 10:06 PM
Originally Posted by Rivermaxx View Post
Neil we are talking about mod1 gears not .8 or 32p gears. A 25 tooth mod 1 is bigger than a 27 tooth .8 or 32p. Bigger than 25 tooth mod 1 steel gear is almost non existant.
Alas, I cannot read, for Im sure the info said Mod1, but then again, I was wrong; rare thing indeed....
Do like those Acer poster girls though, think RCM should sex up its image too a bit...
speedracer1129
08.31.2009, 10:27 PM
For your viewing pleasure................
24t, 25t on 2 speed adaptor, 30t, 30t
Name:	For Sale 018.jpg
ID:	7643   Click image for larger version
Name:	For Sale 019.jpg
ID:	7644   Click image for larger version
Name:	For Sale 020.jpg
FS: Medusa 80mm 1600kv 5mm
FS: Mega 22/30 3 1270kv 5mm
FS: Datalogger V3 150amp version
speedracer1129
08.31.2009, 10:32 PM
AND BEFORE THE QUESTION ARRISES.................
they ARE for sale!! I am no longer doing anything fast. I will let you new speed guys have the fun!!! Here is what I have left:
1- 24T 5mm
1- 25T w/2 speed adaptor
1- 30T 5mm
2- 30T 5mm Acetyl
1- 30T 6mm Acetyl
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
08.31.2009, 10:35 PM
so are those mod 1 or 32p?
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
Rivermaxx
08.31.2009, 10:37 PM
Will the plastic 30 tooth work with brushless power since the aluminum gear is the wrong degree pressure angle ?
speedracer1129
08.31.2009, 10:48 PM
mod1
speedracer1129
08.31.2009, 10:50 PM
I ran the plastics for 1 to 1 ratio on a 10S truggy and had no problems with them. Ofcourse, your trigger finger might be more anxious than mine........
