zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.17.2010, 02:31 AM
Okay, do you see the labeling though Brian? If you ignore the drawing they provide, doesn't it look like they are switching the + batt terminal?
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
05.17.2010, 01:15 AM
Actually, we need to wait until we see the actual instructions for this.
-Chad
PM ME IF YOU HAVE THE BELOW:
rawfuls
roofles.
rawfuls's Avatar
05.17.2010, 03:39 PM
Got a quick email back...
"Hi Justin,
Thank you for your e-mail. The circuit diagram that you provided does
look correct.
Best regards,
Don Clark
Batteryjunction.com
-----Original Message-----
Sent: Monday, May 17, 2010 12:16 AM
To: CustomerService
Subject: Contact Request Form
My Question
Comment: ************Hi, your labels on the Protection Circuit Module
(PCB) for a single cell Li-ION:
http://www.batteryjunction.com/prcimopcbfor.html
Is quite confusing.
I'm not sure which the P , B *and such are actually going to, so would
like to make sure.
If I wire up a battery, to connect to this module, which will then wire
out to a connector, would this diagram be correct? Thanks!
05.17.2010, 03:45 PM
That photobucket pic is missing. It would be nice to know what the proper wiring was...
zero: The labeling is a bit "crappy", but the pic I posted makes sense assuming I am reading their label correctly.
No matter what, if I were to buy that device, I would be reverse-engineering it to make sure I knew what goes where. Those ICs are most likely commonplace for those types of modules, so a datasheet lookup should tell the tale.
rawfuls
roofles.
rawfuls's Avatar
05.17.2010, 03:52 PM
I think it's around post 29
05.17.2010, 03:56 PM
Ok cool, that's just like the diagram I posted except I put the battery on top and the load/charger (connector in post 29's diagram) on the bottom. Same connections though...
Chadworkz
Chadworkz's Avatar
05.17.2010, 05:06 PM
here is the fixed picture he posted above...
-Chad
rawfuls
roofles.
rawfuls's Avatar
05.17.2010, 05:35 PM
Thanks Chad:
I'll be waiting for the "MintyBoost" to see if I can even solder it up, and get it working before I order a LiPo and the board...
