roofles.
LVC/LVA for a 1 Cell LiPo? -
05.16.2010, 12:24 PM
Hey guys, I have a quick question.
Since I'm making a USB charger, I was thinking of using a single cell lipo, over 2 or 4 double A's.
Using a single cell lipo to power a USB charger directly would surely be moe efficient an last longer than standard AAs.
Now if I DO use a single cell, is there any way I can mod, or pick up a LVC, afterall, I don't want something smoking on me during class, nor so I want a puffed lipo in class!
Any help/suggestions/advice would be appreciated!
05.16.2010, 01:22 PM
roofles.
05.16.2010, 03:26 PM
Originally Posted by suicideneil
Wow, didn't see that.
But what the hell do I do with that
Z-Pinch racer
05.16.2010, 05:34 PM
Is this USB charger for powering your laptop? If so, why not use A123 cells? You could buy a 15Ah prismatic for $37 + shipping and that could go in your bag with a few heat shrink layers on it for protection, or even some stiff rigid plate for added security?
roofles.
05.16.2010, 05:36 PM
Not a laptop charger, but rather a USB charger for little things, like my phone, iPod, etc...
UE Supermaxx Addict!
05.16.2010, 06:18 PM
That PCB is wired between the LiPo battery and the device, and it acts as a voltage/amperage traffic cop, stopping the LiPo from over-discharging or doing exactly what you don't want it to do.
If you take apart certain Lithium batteries for things like cell-phones and audio-devices, you almost always see a similar PCB wired to the battery to keep it from over-discharging or over-charging.
The PCB linked to above is EXACTLY what you need.
-Chad
› PM ME IF YOU HAVE THE BELOW:
› VBS, CVDs, GM Single-Speed, OTB, Ultramaxxed, Super6, Strobe, Sprong, CNR Brake, UE Hex, DUH Towers, Predator, Blackbird, GA Blue Screws, HCR F/R Skids & Mutant
roofles.
05.16.2010, 06:22 PM
I meant more along the lines of what to solder it to (Positive to ?, Negative, etc.)
05.16.2010, 06:32 PM
It will come with instructions, but it is pretty self-explanatory...
-Chad
roofles.
05.16.2010, 06:40 PM
So I would assume, the left, bigger pad is for the positive, right side is for the negative side, what's the middle for? Just a different cable to charge?
If it's THAT simple, I'll definitely be trying this out..
05.16.2010, 06:53 PM
Remember, it is used to make sure the battery is not over-charged, or over-discharged...so, that's why there are three pads. Two are positive (+) and one is a common ground/negative (-).
-Chad
Z-Pinch racer
05.16.2010, 06:59 PM
The circuit lies between the negative batt and negative load&charge, both the batt + and load + are connected to the same contact point.
roofles.
05.16.2010, 07:01 PM
Ah, but my real question is where are the polarities, and such?
Is the far left both positive and the right is the ground?
05.16.2010, 07:02 PM
The top part of the diagram is your battery, the bottom part is the wires going to your charger circuit. B+ is battery positive, and so on.
roofles.
05.16.2010, 07:06 PM
Okay, so the B+ is battery positive, B-, battery negative, P+/- is...
yeah, I'm dumb.
05.16.2010, 07:10 PM
The wires going to the charger circuit.
