02.11.2007, 12:11 PM
Originally Posted by Defcon
Bummer the Wanderer 9xl is out of stock would the 10xl be good or should I just go with the fiago 9xl?
Well, the 10xl will obviously be a little slower than the 9xl at the same voltage. If that's OK with you, or you can up the voltage a little to compensate, or don't mind gearing up a tad to compensate, then go with the 10xl.
Defcon
02.11.2007, 12:23 PM
How about the feigao 540 8xl is that getting too hot?
02.11.2007, 12:25 PM
I assume you are going with 4s? The 8XL should be perfectly fine with that.
neweuser
neweuser's Avatar
02.12.2007, 10:17 AM
8xl should be fine. Have you contacted Mike to see if he may havea 9xl around maybe? But on 4s, an 8xl would be better anyway.
