jzemaxx
02.27.2009, 03:37 PM
Center diff is nice, but that would disqualify me from racing. To run in production monster truck is has to use a trans. So I will venture down another path. I think an emaxx tranny is the way to go.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
Hardstyle
Hardstyle's Avatar
02.27.2009, 03:52 PM
I did some measuring from my emaxx tranny. It was about 1cm too wide from the motor plate to get it to fit between tvp's. But I think it would fit with the One side only motor plate... or if you'd keep the tranny little bit higher. Don't know about the axles angles then, might disturb them to work properly.. But hell ye, give it a shot then see who will get the truck running first
02.27.2009, 04:10 PM
Well are you sure what if you lock the tranny with a cen diff locker... would that not count...
IIRC the koysho spurs sit so you could use 44 or 46t...
I'd just use ali rod on the sides to attach to the tvps and use two diff top braces to stiffen the setup in the direction of the tvps
Hardstyle
Hardstyle's Avatar
02.27.2009, 05:32 PM
Arct1k What about this one, there would be all-in-one?
02.27.2009, 05:46 PM
That looks like a losi eight - Only the metal bits come in the kit from Mike.
Just put a note on the main page - lots of people will have a spare diff mount from their conversion. I should have a jammin one at home if you want it...
Hardstyle
Hardstyle's Avatar
02.28.2009, 07:18 AM
Pmed ya!
I totally forgot to look what our lhs has to offer..
Hardstyle
Hardstyle's Avatar
03.01.2009, 06:58 PM
Arct1k did you got my pm? It's ok if you didn't I did some searching from my lhs's. I think I found everything.
Here is some stuff what I found:
- Spider Diff Center Hobao Hyper 7 & 8
- Diff Box Hyper 7
- Hobao Hyper 8 Diff Mount
- XB808 Center Diff
- XB808 Diff mount
- XB8EC Diff Mount
- 50T CENTER DIFFERENTIAL HARDENED LIGHTN. STADIUM PRO
- CENTRE DIFF HOUSING SET
- Center Diff STR
Just a few examples.. Im quite interested about the spider diff, that should be strong enough? I really don't know much about these center diffs, haven't own a buggy ever
Can I get stuffs cheaper from Mike?
Edit:.
Forget to mention that money isn't now so big trouble.
Hardstyle
Hardstyle's Avatar
03.02.2009, 04:28 PM
Monolog continues. So can I go wrong if I order Hobao Hyper Spider Diff to center and Hobao Hyper 8 Diff Mount to it? If I can choose what spur gear with it what would be good 46t? I might also order upper brace plate to it, so I don't have to make one myself.. Hows that sounds?
Hardstyle
Hardstyle's Avatar
03.04.2009, 03:09 PM
Dang this thread is too exciting
OK. I throwed the spider diff idea away and ordered basic hb lightning stadium center diff 50T. Like Arkt1c recommend at the first place..
Just to be sure, are the diff and center diff housing the right ones now. Look the pic below..
93firebird
03.04.2009, 11:15 PM
Does anyone know what type of pinion gears would be needed to run with the stock tranny of the genesis?
jzemaxx
03.04.2009, 11:38 PM
Mod 1 gears.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
93firebird
03.04.2009, 11:40 PM
thanks for the quick reply!
One more thing, are the gears for the two speed adapter mod 1? They don't say in the description.
http://www.rc-monster.com/proddetail...cm2spdgears1st
Hardstyle
Hardstyle's Avatar
03.10.2009, 11:41 AM
Center diff and housings arrived today. And with my luck the housings seems to be wrong ones It's very minor problem. Housing is 15mm and bearings are 16mm. So I think I could work that housing a little bit. Maybe drill the hole little bit bigger.
Good news is that the cen dogbone fits there perfectly.
Arct1k, is that center diff one you recommended? Might those phillips screws be a problem with Mike's mount?
03.11.2009, 07:42 AM
I'm guessing you have the Hot Bodies Center Diff Hardened Lightning centre diff - The issue is you have the HB LS10 centre diff mounts - you need the LSP centre diff mounts...
03.11.2009, 07:44 AM
http://www.amainhobbies.com/product_...oducts_id/2768
Hot Bodies Center Diff. Mount (Lightning Stadium Series)
[HBSC8150]
