07.20.2009, 10:24 PM
on a side note: when I started in brushless I fried a very expensive Hacker setup, several hv-maxx setups and countless nimh batteries. For you're first brushless setup you're really not doing too bad. Wrenching and failures are part of the hobby. Think top fuel dragsters that need to rebuild their motor after each run.
link for neu batts: http://www.neumotors.com/Site/Welcome.html
RCM batts (they're all good) http://www.rc-monster.com/batteries.php
your batteries are your power source, the more you spend on batteries the happier you'll be
Wild YFZ 450
yfz 450.
Wild YFZ 450's Avatar
07.20.2009, 10:25 PM
Originally Posted by Freezebyte View Post
Everyones suggesting other Lipos, but no ones providing links on where to purchase them.
Google.com
  Send a message via AIM to Wild YFZ 450
07.20.2009, 10:32 PM
You can get the hyperion G3 packs at all e rc. However support Mike and get some lipos from the RCM store!
Or you can look around like the rest of us do.
Any luck with returning the packs to SMC?
Metallover
RC-Monster Spudgunner
Metallover's Avatar
07.20.2009, 10:34 PM
Lots all at the RCM store
But if you need more selection-
Hyperion 35c vx packs - http://www.allerc.com/
C-tech - http://www.rc-monster.com/products.php?cat=120
Zippies (if you're on a budget)- http://www.hobbycity.com/hobbycity/s...5&ParentCat=85
Polyquest (enerland, cheaper price) - http://www.hobbycity.com/hobbycity/s...7&ParentCat=85
The flightpowers out now are enerland but the new EON-X packs will be similar to hyperion packs, probably better.
Finnster
KillaHurtz
Finnster's Avatar
07.20.2009, 11:59 PM
Originally Posted by Wild YFZ 450 View Post
Google.com
helpmyfingersarebroken.com
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
07.21.2009, 01:18 AM
Oh yeah, Mike has a couple Hyperion G3 packs in stock.
Do you need two seperate packs for the Flux? If not, then get either of these:
http://www.rc-monster.com/proddetail...=HPLG33542005S
http://www.rc-monster.com/proddetail...=HPLG32550005S
The first one is a 4200mah 35C 5s pack, and the second a 5000mah 25C 5s pack.
Metallover
Metallover's Avatar
07.21.2009, 01:28 AM
Wow those things are cheap.
zeropointbug
Z-Pinch racer
07.21.2009, 03:50 AM
Ah yah, you just figure that out?
They are as far as I know the best value in the high end lipo packs.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.21.2009, 09:29 AM
I would say, great price....!
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Finnster
KillaHurtz
Finnster's Avatar
07.21.2009, 09:31 AM
Nice!
JThiessen
JThiessen's Avatar
07.21.2009, 09:52 AM
Originally Posted by fastbaja5b View Post
Yeah I did actually, likely a contributing factor!
Can you run a 3s and a 2s on the Flux? The manual says both pack needs to be equal. I didn't think I could even run a 5000mah and a 5100mah pack or a 28C and a 30C pack, what I interpreted was both packs must be identical.
I was banned by hopmeup on ebay because I left them neutral feedback based on the quality of the product they were selling. Dont base your opinion of A123's on what you got from them - they really are good reliable power. Not as much power as lipo, but likely much more reliable.
To do a 2S/3S set up (as 5S), you just need to remove the Flux battery wires, and insert a single pack connector - this will make the flux think it is seeing one pack. Oh, and you'll need a series wiring connector for the packs (or is that parallel???) Check Brians speed calculator page on battery wiring to verify the layout.
skellyo
skellyo's Avatar
07.21.2009, 10:02 AM
You don't need to do anything. Just use a single 2S pack and a single 3S pack and use the existing connectors on the Flux ESC. They'll plug right in and be in series for 5S operation. If you do what you stated to modify the connection, you've just wasted your time since it's the same electrically regardless of where the series connection is.
Wild YFZ 450
yfz 450.
07.21.2009, 11:13 AM
Start>All programs>Accessories>Ease of Access>On Screen Keyboard.
Freezebyte
07.21.2009, 09:00 PM
Still no reply from SMC
fastbaja5b
fastbaja5b's Avatar
07.21.2009, 09:04 PM
Ok thanks, do you find the higher internal resistance of A123 vs Lipo presents an issue?
Say Less, Do More.
