Originally Posted by cheesecake
how would a teken r1 pro do in a truggy on 5s with a neu 1515 2.5d im thinking of getting one for the and i was going to find a way to mount a fan on it
I can't comment fully , but i have run my R1 Pro with 35v cap and external bec in my X2 truggy with no problems , set up similar to yours 5s , Medusa 1600kv motor. However it was winter over here and i only ran it a couple of times for around 10mins each time and heat was no issue .
Didn't want to push it fully as i bought the R1 to run in my buggy which is on it's way ( Hot Bodies D8
) but while waiting for my MMM v2 to arrive i thought i would give it a little run in the truggy .
If you could get a fan on it i don't think you will have any problems . You could use a piece of thin alloy mount the R1 Pro to it then bend it up to face the solder tabs , then attach a fan to the alloy which is facing the solder tabs ( nearly did this in the truggy while waiting forever for the MMM ) .
