BP-Revo
BMW M Power!
BP-Revo's Avatar
03.23.2007, 11:45 PM
Mike sells 1/8inch bore Mod1 Pinions. He also sells the 5mm bore Hardened Steel pinions that are for use with steel spurs. I'm quite sure he will be able to make you a hardened 1/8inch bore pinion.
03.24.2007, 12:12 AM
I already have the regular 1/8" bore Mod1 pinion, but it's for plastic spurs. But after reading posts where the hardened steel spurs don't last, I am hesitant to use them. I'm just trying to find a way to use a plastic spur on a diff that won't fit it. I might just email Mike and see what he thinks...
BP-Revo
BMW M Power!
BP-Revo's Avatar
03.24.2007, 12:53 AM
Ooo...this is going to be a pretty big obstacle...let me know what you do Brian.
03.24.2007, 12:56 AM
Oh, I will. I emailed Mike to see what he thinks.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.24.2007, 01:13 AM
Great pics... cool.
Now I have a some questions....
1.How mcuh too short is the outdrive... with the kyosho gear shaved down? It looks pretty close. I wonder if it would work with the inside of the kysoho gear also shaved thinner (on the inside, the area around where the o-ring is)
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
03.24.2007, 01:31 AM
That's an idea. I wonder how I'm going to do this while still making it perfectly even and flat?
There's actually one more measurement I need to take and post a pic of...
glassdoctor
TEAM FUSION
03.24.2007, 01:43 AM
Nevermind the above pic..... you already said the stock bearing is 10mm.
Also I measured the stub on the kyosho which is right about 10mm. It's just a hair under 10 then tapers to just over 10. I wondered if you could use a spacer sleeve to make the stock bearing fit right on the kyosho... and fit at least part way onto the fat part of the stub. Just a little sanding on the stub and the bearing would fit. That would let the stock outdrive fit farther into the diff... maybe enough to work.
Make sense???
The problem then is that it's still a mod1 gear and you are using a MM. 1/8" bore mod1 gears are a pain... maybe Mike could hook you up with a spacer so you can use the 5mm gears.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
glassdoctor
TEAM FUSION
03.24.2007, 01:46 AM
I know that even if all that worked... the gear might rub on the diff mounts.. so you would have to do something to hold it from hitting the mount
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
03.24.2007, 02:11 AM
Here's another picture showing the relative heights. Each spur is resting on a standoff of the exact same height. The standoffs are sitting on the gear mounting plane. You can see that I can't shave enough off the Kyosho spur for the outdrive to reach inside the diff enough, while still being able to use a bearing. Don't forget, I'm limited by the length of the outdrive, not so much the diff mount...
And even if I could get this to work, I'm still stuck trying to find a bearing...
glassdoctor
TEAM FUSION
03.24.2007, 02:45 AM
Would be nice to replace the whole thing with a slipper diff with standard 48 or 32p gears. But I don't know one that would work at the moment :)
I think I would do the piggyback gear... with a 46t gear so you can line up the teeth perfectly and drill holes to bolt them together. It would look interesting but it would work great.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
matto247
03.24.2007, 05:06 AM
dude on ebay i saw a person calld like world of bearings he sells like frm R/C bearings to skateboards and so on.
riceman
RC-Monster Gold
riceman's Avatar
03.24.2007, 11:31 AM
Oh man - That is a real downer about that spur gear. I'm so glad you are posting all of this because it's nice to see everyone's feedback for when I start my project...speaking of which. Guess what I happened to track down at one of my LHS's? :027:
I scoured the internet looking for one and hear it was in my back yard!
I know Brian already showed his next to his Jato but here are some more comparisons:
Next to it's big brother CRT
And an 18t, GT2
Like Brian I was thinking about a MM4600 or 5700 too but it looks like there are quite a few issues to work out with the metal spur and finding a 1/8 in bore Mod 1 pinion. Anyway, just some other thoughts:
Again just for size comparisons. Here is a Feigao 7XL and Maxamps 3S 4000 mah pack in place
Serum
Serum's Avatar
03.24.2007, 11:35 AM
a 7XL on 3S, that will fly! it was fun in my maxx.. so it's fun in a 1/16th!
03.24.2007, 02:17 PM
Oh yeah! I sent Mike an email about this last night and he said the CRT.5 is one of his "short listed" projects since he got one of these himself! :) He said he may have to make a custom spur setup or maybe another diff setup, but wasn't sure yet.
I still won't stop thinking about solutions, but at least there are others that have this now so I'm sure an ideal solution will present itself.
Riceman: Good for you! :) The CRT looks nicer in person doesn't it? So, when's yours going to be done so I can "borrow" ideas? :)
squeeforever
squeeforever's Avatar
03.24.2007, 02:55 PM
Brian, why not make a sleeve to use the stock bearing. Just make a sleeve out of some kind of composite to sort of fill the gap since you can't find a bearing the right size.
