Lvc?
DickyT
Lvc? - 02.13.2008, 11:38 AM
After having my nerves calmed by Artur about running 5s on my MM that he modified i'm going to go for it. I will need to disable the onboard LVC though.
What is a solid external LVC? I'm ordering Lipo gear Friday and want to order this at the same time.
I have read about the li-saver but seen that if you have reverse enabled, which I do that it can send your truck into full reverse, that sounds bad with a 1515 1y and 5s.....
jhautz
jhautz's Avatar
02.13.2008, 11:52 AM
Mike sells a version made specifically for cars. It fixes the reverse problem that is encountered when using the standard airplane version.
Here:
http://www.rc-monster.com/proddetail...rod=lisavercar
to make it...
or break it...
Silent...But Deadly
DickyT
02.13.2008, 11:59 AM
And I get to buy it from Mike too! thanks.
DickyT
02.15.2008, 10:58 AM
Ordered the LVC, now ofr a setup question.
it seems simple enough but I have a ubec in the loop as well.
do I connect the lvc to the ubec or esc cable to plug into the rx?
the battery part looks self explanitory.
02.15.2008, 07:54 PM
I think you might need a Y-cable unless you have another spare slot on the RX. The lvc goes between the esc and channel 2 slot on the Rx, simple enough, but the ubec also needs to plug into the channel 2 slot on the Rx... yep, Y-cable needed I think.
DickyT
02.15.2008, 09:53 PM
I have been plugging the ubec into the battery slot on rx in my rusty, but that was with just the ubec.
bdebde
That's All Folks!
bdebde's Avatar
02.15.2008, 11:04 PM
You can leave the bec in the batt slot, just put the lvc between the esc and receiver
DickyT
02.15.2008, 11:26 PM
thank you.
